Ana içeriğe geç
Shark ION RV754 Suction Motor Replacement
Neye ihtiyacın var
  1. Shark ION RV754 Suction Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Place the unit on its back with the wheels facing up.
    • Use a Phillips #1 screwdriver to remove the single screw securing the battery compartment door.
    • Use your finger to lift off the battery door using the small indent next to it.
    FixBot'a Sor
  2. Shark ION RV754 Suction Motor Replacement: adım 2, 3 resimden 1. Shark ION RV754 Suction Motor Replacement: adım 2, 3 resimden 2. Shark ION RV754 Suction Motor Replacement: adım 2, 3 resimden 3.
    • Lift the battery out just above the compartment to access the battery connector.
    • Squeeze the tab against the connector and pull it straight up to disconnect it.
    • Remove the battery completely.
    FixBot'a Sor
  3. Shark ION RV754 Suction Motor Replacement, Wheels: adım 3, 3 resimden 1. Shark ION RV754 Suction Motor Replacement, Wheels: adım 3, 3 resimden 2. Shark ION RV754 Suction Motor Replacement, Wheels: adım 3, 3 resimden 3.
    • Use a TR15 Torx security screwdriver to remove five 13.85 mm screws from the left and right wheel assemblies.
    FixBot'a Sor
  4. Shark ION RV754 Suction Motor Replacement: adım 4, 3 resimden 1. Shark ION RV754 Suction Motor Replacement: adım 4, 3 resimden 2. Shark ION RV754 Suction Motor Replacement: adım 4, 3 resimden 3.
    • Lift the wheel assembly out to access the cable connectors that are attached to the wheels.
    • Squeeze the tab against the connector and pull it straight out to disconnect it from the wheel.
    • Remove the wheel assembly.
    • Repeat the steps to remove the other wheel.
    FixBot'a Sor
  5. Shark ION RV754 Suction Motor Replacement, Suction Motor: adım 5, 1 resimden 1.
    • Press the dust bin latch and slide the bin out to remove it.
    FixBot'a Sor
  6. Shark ION RV754 Suction Motor Replacement: adım 6, 3 resimden 1. Shark ION RV754 Suction Motor Replacement: adım 6, 3 resimden 2. Shark ION RV754 Suction Motor Replacement: adım 6, 3 resimden 3.
    • Remove the 5 9.30 mm screws securing the bumper trim using a Torx TR8 screwdriver.
    • Use an opening tool or spudger to release the clips securing the bumper trip.
    • Carefully pull the bumper trim off the vacuum.
    • Lift the front bumper off of the vacuum.
    FixBot'a Sor
  7. Shark ION RV754 Suction Motor Replacement: adım 7, 3 resimden 1. Shark ION RV754 Suction Motor Replacement: adım 7, 3 resimden 2. Shark ION RV754 Suction Motor Replacement: adım 7, 3 resimden 3.
    • Use a TR8 Torx Security screwdriver to remove the five 13.9 mm screws from the bottom of the vacuum.
    • These 13.9 mm screws are in deep recesses and the TR8 screwdriver will need an extension or a narrow shaft to reach them.
    • Remove the two 9.3 mm screws from the bottom of the vacuum near the dust bin cavity using a TR15 Torx Security screwdriver.
    • To separate the vacuum body, place one hand on the bottom and pull with the other from the brush roll recess.
    FixBot'a Sor
  8. Shark ION RV754 Suction Motor Replacement: adım 8, 3 resimden 1. Shark ION RV754 Suction Motor Replacement: adım 8, 3 resimden 2. Shark ION RV754 Suction Motor Replacement: adım 8, 3 resimden 3.
    • Remove the 6 circuit board wire connectors on the left side of the board as shown.
    • Remove the 6 circuit board wire connectors on the right side of the board using the same method.
    • For helpful tips on removing the cables from the board, take a look at the Recognizing and Disconnecting Cable Connectors guide.
    • Be careful when disconnecting the wire connectors from the circuit board to avoid damage to the wires, sockets, or circuit board.
    • It is a good idea to keep a reference picture for reattaching the wires later, since many of them are very similar in color and size.
    FixBot'a Sor
  9. Shark ION RV754 Suction Motor Replacement: adım 9, 2 resimden 1. Shark ION RV754 Suction Motor Replacement: adım 9, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the five 9.80 mm screws from the circuit board.
    • Gently remove the circuit board by pulling up on it as shown and set it aside.
    FixBot'a Sor
  10. Shark ION RV754 Suction Motor Replacement: adım 10, 3 resimden 1. Shark ION RV754 Suction Motor Replacement: adım 10, 3 resimden 2. Shark ION RV754 Suction Motor Replacement: adım 10, 3 resimden 3.
    • Remove the three 11.6 mm screws securing the suction motor using a Phillips #1 screwdriver.
    • Disconnect the remaining wires connected to the suction motor and move the wires aside to avoid pulling on them when removing the suction motor.
    • Pull up on the suction motor to remove it.
    FixBot'a Sor
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
James Holland
362 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 201
