Ana içeriğe geç
Shark ION Robot 750 Main Wheel Assembly Replacement
Neye ihtiyacın var
  1. Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: adım 1, 3 resimden 1. Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: adım 1, 3 resimden 2. Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: adım 1, 3 resimden 3.
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 2, 2 resimden 1. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 2, 2 resimden 2.
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 3, 2 resimden 1. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 4, 2 resimden 1. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 4, 2 resimden 2.
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 5, 3 resimden 1. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 5, 3 resimden 2. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 5, 3 resimden 3.
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 6, 1 resimden 1.
    • Lift the outer shell to expose the Shark’s interior.
  7. Shark ION Robot 750 Main Wheel Assembly Replacement, Main Wheel Assembly: adım 7, 2 resimden 1. Shark ION Robot 750 Main Wheel Assembly Replacement, Main Wheel Assembly: adım 7, 2 resimden 2.
    • Disconnect each of the cable connectors attached to the motherboard to free the wheel assembly from the vacuum for both the left and right wheels.
    • For helpful details on disconnecting different types of connectors, check out the Recognizing and Disconnecting Cable Connectors guide.
  8. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 8, 3 resimden 1. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 8, 3 resimden 2. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 8, 3 resimden 3.
    • Use a spudger or your fingers to detach all of the cables from the connectors on the motherboard that connect to the wheels.
    • This guide demonstrates the right wheel removal but you can use this guide to remove the left wheel assembly as well.
    • Unhook the remaining wires that are connected to the back of the wheel.
    • Do not rip the wires when removing them from the wheel and motherboard.
  9. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 9, 3 resimden 1. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 9, 3 resimden 2. Shark ION Robot 750 Main Wheel Assembly Replacement: adım 9, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the three 12 mm screws that hold the right wheel in place.
    • Be careful not to strip the screws when removing them from the wheel. Take a look at this guide for Screwdriver Best Practices.
    • Remove the right wheel assembly from the socket.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Talia Marquez
97 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 117
