Ana içeriğe geç
Skullcandy Crusher Wireless Battery Replacement
Neye ihtiyacın var
    1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: adım 1, 2 resimden 1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: adım 1, 2 resimden 2.
      • Take your headphones and hold them upside down for better control with your hands.
      FixBot'a Sor
      Yorum Ekle
    2. Skullcandy Crusher Wireless Battery Replacement: adım 2, 2 resimden 1. Skullcandy Crusher Wireless Battery Replacement: adım 2, 2 resimden 2.
      • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
      • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
      FixBot'a Sor
      Yorum Ekle
    3. Skullcandy Crusher Wireless Battery Replacement: adım 3, 1 resimden 1.
      • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
      FixBot'a Sor
      Yorum Ekle
    1. Skullcandy Crusher Wireless Battery Replacement, Battery: adım 4, 2 resimden 1. Skullcandy Crusher Wireless Battery Replacement, Battery: adım 4, 2 resimden 2.
      • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
      • You have to work on the right-side earphone.
      FixBot'a Sor
      Yorum Ekle
    2. Skullcandy Crusher Wireless Battery Replacement: adım 5, 3 resimden 1. Skullcandy Crusher Wireless Battery Replacement: adım 5, 3 resimden 2. Skullcandy Crusher Wireless Battery Replacement: adım 5, 3 resimden 3.
      • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
      • Gently pry the speaker part away from the frame of the headphones.
      FixBot'a Sor
      Yorum Ekle
    3. Skullcandy Crusher Wireless Battery Replacement: adım 6, 2 resimden 1. Skullcandy Crusher Wireless Battery Replacement: adım 6, 2 resimden 2.
      • Separate the headphone speaker assembly from the headphone speaker frame.
      FixBot'a Sor
      Yorum Ekle
    4. Skullcandy Crusher Wireless Battery Replacement: adım 7, 3 resimden 1. Skullcandy Crusher Wireless Battery Replacement: adım 7, 3 resimden 2. Skullcandy Crusher Wireless Battery Replacement: adım 7, 3 resimden 3.
      • Remove the battery from the headphone housing.
      • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
      • For more information on soldering, please, use this Solder and Desolder Connections guide.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Val
1.227 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22S1G33
1 Üye
19 adet Kılavuz yazıldı
5Kılavuz Yorumları
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - Yanıt Paylaş
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen - Yanıt Paylaş
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - Yanıt Paylaş
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - Yanıt Paylaş
Am I able to send my headphones to you to be fixed?
If I can, what would the cost be?
I have two headphone sets
Jeffrey Timothy Valerie - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 68
Son 30 gün: 222
Her zaman: 15,691
