Ana içeriğe geç
Skytex Skypad Alpha 2 Antenna Replacement
Rebecca Ramirez
Rebecca Ramirez ve 4 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 dakika
Orta
By following this guide one is able to access the antenna of the Skypad Skytex Alpha 2 tablet in two steps. These steps include removing any metallic tape that holds the antenna and removing soldered connections.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Skytex Skypad Alpha 2 Antenna Replacement, Back Cover: adım 1, 1 resimden 1.
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Antenna Replacement: adım 2, 2 resimden 1. Skytex Skypad Alpha 2 Antenna Replacement: adım 2, 2 resimden 2.
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Antenna Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Antenna Replacement: adım 4, 1 resimden 1.
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Antenna Replacement, Antenna: adım 5, 1 resimden 1.
    • Remove the metallic electrical tape, just enough, to allow the antenna to hang freely.
    • Remove all black and yellow tape, if necessary, on the motherboard.
  6. Skytex Skypad Alpha 2 Antenna Replacement: adım 6, 1 resimden 1.
    • Remove the soldered connections to separate the antenna wire from the motherboard.
    • The antenna wire will be connected to the motherboard with 2 connections, so be sure to remove both with the soldering iron.
    • Follow the link below for further soldering information: How To Solder and Desolder Connections.
    • Soldering irons require a large amount of heat; use caution when performing this step. Excessive heat can damage parts of your device; do not leave the soldering iron on connections for extended periods of time.
  7. Skytex Skypad Alpha 2 Antenna Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the antenna from the tablet using a pair of tweezers.
    • The antenna is actually fastened inside the back case of the tablet, pull gently to free it from the adhesive.
Sonuç
Rebecca Ramirez
481 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-5, Williams Fall 2015 Baylor, Team 6-5, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G5
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 157
