Giriş
In the situation that your Sony BDP-BX510 port board is not working despite trying the solutions on the troubleshooting page, you may need to replace it. This guide will provide you with the steps required to safely remove your port board for replacement.
Neye ihtiyacın var
Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
Apply slightly more pressure to the left side until it unhooks then unhook the right side.
Close the disk tray by pressing the eject button again, then power off the device and unplug it.
Find the large ribbon cable that connects the port board to the motherboard.
Carefully pull directly upwards to disconnect the cable.
