Ana içeriğe geç
Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement
Tong Tang
Tong Tang ve 4 diğer katkıda bulunanlar
En son September 4, 2019 tarihinde güncellendi
10 dakika
Orta
In order to reach the flash capacitor, you have to remove the front and back panel, the button board and the top cover of the device. Be very careful when you remove these parts.
Neye ihtiyacın var
Aletler
  1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 2, 1 resimden 1.
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 3, 1 resimden 1.
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: adım 4, 3 resimden 1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: adım 4, 3 resimden 2. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: adım 4, 3 resimden 3.
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 5, 3 resimden 1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 5, 3 resimden 2. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 5, 3 resimden 3.
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 6, 3 resimden 1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 6, 3 resimden 2. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 6, 3 resimden 3.
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Button Board: adım 7, 2 resimden 1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Button Board: adım 7, 2 resimden 2.
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 8, 2 resimden 1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: adım 8, 2 resimden 2.
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: adım 9, 3 resimden 1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: adım 9, 3 resimden 2. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: adım 9, 3 resimden 3.
    • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Lift the capacitor from the assembly.
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the flash board.
Sonuç
Tong Tang
590 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-1, Blackwell Fall 2016 USF Tampa, Team 17-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,013
