Ana içeriğe geç
Sony Cyber-shot DSC-T9 Motherboard Replacement
Stephannie Allen
Stephannie Allen ve 2 diğer katkıda bulunanlar
En son December 10, 2020 tarihinde güncellendi
Tahmin yok
Zor
This guide will allow the user to access the motherboard for installation, replacement, or removal.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony Cyber-shot DSC-T9 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 2, 1 resimden 1.
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: adım 3, 3 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: adım 3, 3 resimden 2. Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: adım 3, 3 resimden 3.
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 5, 1 resimden 1.
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 6, 1 resimden 1.
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 Motherboard Replacement, Back Cover: adım 7, 1 resimden 1.
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 9, 3 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 9, 3 resimden 2. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 9, 3 resimden 3.
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 10, 3 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 10, 3 resimden 2. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 10, 3 resimden 3.
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 12, 1 resimden 1.
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 Motherboard Replacement, LCD: adım 13, 1 resimden 1.
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 14, 1 resimden 1.
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 15, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 16, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 16, 2 resimden 2.
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 17, 1 resimden 1.
    • The LCD is now removed from the camera.
  18. Sony Cyber-shot DSC-T9 Motherboard Replacement, CCD Module: adım 18, 1 resimden 1.
    • This is the CCD module.
  19. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 19, 1 resimden 1.
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  20. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 20, 1 resimden 1.
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  21. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 21, 1 resimden 1.
    • The CCD module is now removed from the camera.
  22. Sony Cyber-shot DSC-T9 Motherboard Replacement, AV Port: adım 22, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement, AV Port: adım 22, 2 resimden 2.
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  23. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 23, 1 resimden 1.
    • Remove metal screw plate.
  24. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 24, 1 resimden 1.
    • Use pry stick to pop off ribbon.
  25. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 25, 1 resimden 1.
    • Remove AV port from camera.
  26. Sony Cyber-shot DSC-T9 Motherboard Replacement, Motherboard: adım 26, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement, Motherboard: adım 26, 2 resimden 2.
    • The battery cover is located here.
    • Pull away from camera to remove.
  27. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 27, 2 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 27, 2 resimden 2.
    • Grip on the top and bottom.
    • Pull up and out to remove motherboard and attached parts.
  28. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 28, 3 resimden 1. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 28, 3 resimden 2. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 28, 3 resimden 3.
    • Flip motherboard parts to position shown.
    • There are three ribbons still attached to the motherboard.
    • Pull these three ribbons to remove remaining parts from motherboard.
  29. Sony Cyber-shot DSC-T9 Motherboard Replacement: adım 29, 1 resimden 1.
    • The motherboard is now removed from the camera.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Stephannie Allen
276 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G1
4 Üyeler
22 adet Kılavuz yazıldı
Bir Yorum
Superb,thank you very much !!!
Vedrasco Victor Vasili - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 766
