Sony Cyber-shot DSC-W55 Lens Replacement
Giriş
1. adıma gitThis guide shows step by step instructions to remove the lens part of the camera.
Neye ihtiyacın var
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
Bu adımda kullanılan alet:Tweezers$4.99
Flip the black secure locks off. Tweezers may be necessary.
Detach the two orange cables.
15 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
My battery stuck in the camera
Farida Easmin - Yanıt
My battery is stuck in the camera
