Ana içeriğe geç
Sony Cyber-shot DSC-WX100 Flash Bulb Replacement
Matthew
Matthew ve 2 diğer katkıda bulunanlar
En son December 16, 2015 tarihinde güncellendi
35 dakika
Zor
Daha iyi giriş
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement, Battery: adım 1, 1 resimden 1.
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 2, 1 resimden 1.
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement, Outer Casing: adım 3, 3 resimden 1. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement, Outer Casing: adım 3, 3 resimden 2. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement, Outer Casing: adım 3, 3 resimden 3.
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift so the plate is high enough that the marked bump is not holding it in place.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help with this step, refer to the video.
  6. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 7, 3 resimden 1. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 7, 3 resimden 2. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 7, 3 resimden 3.
    • Peel back the copper cover and black tape from the motherboard to reveal the connection port.
    • Using the plastic opening tool, release the black bar on the connection port so that the bar is vertical.
    • Pull the tab out.
  7. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 8, 1 resimden 1.
    • Pull back on the case, then pull the entire tab out from the case.
  8. Sony Cyber-shot DSC-WX100 Flash Bulb Replacement: adım 9, 1 resimden 1.
    • Solder the 4 marked nodes and the remove the flash bulb from the sheet.
    • For help on soldering, refer to this Guide.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew
583 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G9
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 828
