Ana içeriğe geç
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
Matthew
Matthew ve başka bir katkıda bulunan
En son June 22, 2015 tarihinde güncellendi
5 dakika
Kolay
This guide will allow one to be able to remove the outer casing of the camera as to allow them to get to the internal parts of the DSC-WX100.
Neye ihtiyacın var
Aletler
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 2, 1 resimden 1.
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 3.
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to gently release the two indicated tabs.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew
583 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G9
2 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where I can buy the Outer Casing..¿??
ING CHARLY - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 940
