Ana içeriğe geç
Sony DSC-RX100MA Screen Replacement
KC Egger
KC Egger ve 4 diğer katkıda bulunanlar
En son February 8, 2021 tarihinde güncellendi
20 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
If your camera's screen isn't working properly, you may need to replace it. Follow this guide to do so!
Neye ihtiyacın var
Aletler
  1. Sony DSC-RX100MA Screen Replacement, Back Cover: adım 1, 3 resimden 1. Sony DSC-RX100MA Screen Replacement, Back Cover: adım 1, 3 resimden 2. Sony DSC-RX100MA Screen Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Screen Replacement: adım 2, 3 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 2, 3 resimden 2. Sony DSC-RX100MA Screen Replacement: adım 2, 3 resimden 3.
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
    Split this step up into multiple steps based on where screws are being removed from or specify how many screws are removed in this step
    Alberto Rodriguez - Yanıt
  3. Sony DSC-RX100MA Screen Replacement: adım 3, 3 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 3, 3 resimden 2. Sony DSC-RX100MA Screen Replacement: adım 3, 3 resimden 3.
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
    2 different types of screws are removed in this step: specify the types
    It is not necessary to remove the hinge screws. It is much easier to remove the back panel with the LCD still attached and not flopping about everywhere.
    cheez - Yanıt
  4. Sony DSC-RX100MA Screen Replacement: adım 4, 2 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 4, 2 resimden 2.
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Screen Replacement: adım 5, 3 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 5, 3 resimden 2. Sony DSC-RX100MA Screen Replacement: adım 5, 3 resimden 3.
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Screen Replacement: adım 6, 2 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 6, 2 resimden 2.
    • Remove the back cover
  7. Sony DSC-RX100MA Screen Replacement, Screen: adım 7, 3 resimden 1. Sony DSC-RX100MA Screen Replacement, Screen: adım 7, 3 resimden 2. Sony DSC-RX100MA Screen Replacement, Screen: adım 7, 3 resimden 3.
    • Move side panel to get access to screws
    • Remove two screws (black 2.5mm) with PH #0 screwdriver
    In the second picture of the side, it is not the upper screw by the USB that needs removing, but the lower one by the SD/battery door
    James Robinson - Yanıt
  8. Sony DSC-RX100MA Screen Replacement: adım 8, 2 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 8, 2 resimden 2.
    • Remove back panel assembly while still keeping ribbon cable attached
    • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
  9. Sony DSC-RX100MA Screen Replacement: adım 9, 2 resimden 1. Sony DSC-RX100MA Screen Replacement: adım 9, 2 resimden 2.
    • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
    It is worth saying that the grey line on the left-hand edge of the flex connector flips up to release the flex.
    And Rew - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
KC Egger
294 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-1, Maness Winter 2017 Cal Poly, Team 21-1, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G1
5 Üyeler
10 adet Kılavuz yazıldı
4Kılavuz Yorumları
Any idea where I can get a set or replacement screws? one came out of my LCD joint and I can’t find replacements anywhere online. I’ve even tried Ebay.
Alberto Lora - Yanıt
Definately be careful with the gold ribbon cable, looked at mine funny and it just snapped in two.. waiting on a replacement now :(
Connor Quinn - Yanıt
I’ve ripped 2 of these before - not fun! Still… cheap enough to buy but delivery took a couple of weeks.
I had a cracked screen so had to take this out to replace as well - problem i’ve had is that although i stuck it down really well (with 3M 1mm double-sided tape, it doesn’t hold great and so the screen has risen a bit and doesn’t sit flush.
Just in the process now of sticking it down again but with a touch of superglue as i need it to hold down a bit better - that should hopefully be me done then :)
Great guide by the way KC Egger - thanks for taking the time to put this together - it’s been a life saver for me!
Jamie Dunkley - Yanıt
Where did you purchase your screen, I’ve been trying to find one from Sony parts dealers and can’t find it. Any links would be helpful, thanks.
Ian Cullen -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 81
Her zaman: 5,112
