Giriş
To complete this Sony NWZ-E473 guide, a soldering iron will be needed. You may want to have someone with soldering iron experience complete that step or watch some basic videos on how to use a soldering iron.
Neye ihtiyacın var
Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
Bu adımda kullanılan alet:Tweezers$4.99
Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
Use a soldering iron to remove the wires from the red and the black terminals.
4 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
