Ana içeriğe geç
Sony NWZ-E473 Battery Replacement
Matthew Hintz
Matthew Hintz ve 7 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
30 dakika
Zor
To complete this Sony NWZ-E473 guide, a soldering iron will be needed. You may want to have someone with soldering iron experience complete that step or watch some basic videos on how to use a soldering iron.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony NWZ-E473 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Battery Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Battery Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Battery Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Battery Replacement: adım 5, 3 resimden 1. Sony NWZ-E473 Battery Replacement: adım 5, 3 resimden 2. Sony NWZ-E473 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Battery Replacement, Battery: adım 6, 2 resimden 1. Sony NWZ-E473 Battery Replacement, Battery: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Battery Replacement: adım 7, 2 resimden 1. Sony NWZ-E473 Battery Replacement: adım 7, 2 resimden 2.
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Battery Replacement: adım 8, 1 resimden 1.
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Battery Replacement: adım 9, 1 resimden 1.
    • Use a soldering iron to remove the wires from the red and the black terminals.
    How many volts battery is it? mhA?
    sriranggan perumal - Yanıt
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Matthew Hintz
327 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Watkins Winter 2015 USF Tampa, Team 17-6, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G6
4 Üyeler
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - Yanıt
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
guy lewit -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 79
Her zaman: 10,093
