Ana içeriğe geç
Sony PS1100 Needle Cartridge Replacement
L Cis
L Cis ve 4 diğer katkıda bulunanlar
En son June 14, 2021 tarihinde güncellendi
10 dakika
Orta
In this guide you will learn how to replace a broken or old needle on a Sony PS1100. The green needle cartridge is one solid component, that must be replaced together. The needle cannot simply be replaced by itself. The Sony VL-30G is the proper cartridge for the PS1100 Record player, and can be found in most record shops.
For More Troubleshooting click the link: Sony PS1100 Troubleshooting
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: adım 1, 3 resimden 1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: adım 1, 3 resimden 2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: adım 1, 3 resimden 3.
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: adım 2, 1 resimden 1.
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: adım 3, 2 resimden 1. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: adım 3, 2 resimden 2.
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: adım 4, 1 resimden 1.
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
L Cis
110 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-8, Donnelly Fall 2014 USF Tampa, Team 1-8, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G8
1 Üye
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 4,902
