Ana içeriğe geç
Sony Xperia XA1 Battery Replacement
Neye ihtiyacın var
  1. Sony Xperia XA1 Battery Replacement, Phone Back Cover: adım 1, 3 resimden 1. Sony Xperia XA1 Battery Replacement, Phone Back Cover: adım 1, 3 resimden 2. Sony Xperia XA1 Battery Replacement, Phone Back Cover: adım 1, 3 resimden 3.
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Battery Replacement, Battery: adım 2, 2 resimden 1. Sony Xperia XA1 Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Disconnect the battery from the motherboard using an opening tool or spudger.
  3. Sony Xperia XA1 Battery Replacement: adım 3, 3 resimden 1. Sony Xperia XA1 Battery Replacement: adım 3, 3 resimden 2. Sony Xperia XA1 Battery Replacement: adım 3, 3 resimden 3.
    • Lift the black tabs on either side of the battery
  4. Sony Xperia XA1 Battery Replacement: adım 4, 3 resimden 1. Sony Xperia XA1 Battery Replacement: adım 4, 3 resimden 2. Sony Xperia XA1 Battery Replacement: adım 4, 3 resimden 3.
    • Lift the pull tab at the bottom to unseat the battery.
    • After unseating the battery with the pull tab, lift it out of the case.
    • Use caution handling the battery. It is extremely delicate.
  5. Sony Xperia XA1 Battery Replacement: adım 5, 2 resimden 1. Sony Xperia XA1 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery entirely.
    • Do not dispose of your old battery in a regular trash can. Please bring your phone battery to a local home depot, best buy, or staples for safe disposal and recycling in the US and Canada. Other places in the world, please contact your local recycling centers.
Sonuç
Lindsey Taysom
205 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 41
Her zaman: 805
