Ana içeriğe geç
Sony a7 AV Port Replacement
Neye ihtiyacın var
  1. Sony a7 AV Port Replacement, Rear Disassembly: adım 1, 1 resimden 1.
    • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
    • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Sony a7 AV Port Replacement: adım 2, 3 resimden 1. Sony a7 AV Port Replacement: adım 2, 3 resimden 2. Sony a7 AV Port Replacement: adım 2, 3 resimden 3.
    • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Sony a7 AV Port Replacement: adım 3, 1 resimden 1.
    • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Sony a7 AV Port Replacement: adım 4, 2 resimden 1. Sony a7 AV Port Replacement: adım 4, 2 resimden 2.
    • Remove the four M 1.5x2mm screws.
    FixBot'a Sor
    Yorum Ekle
  5. Sony a7 AV Port Replacement: adım 5, 3 resimden 1. Sony a7 AV Port Replacement: adım 5, 3 resimden 2. Sony a7 AV Port Replacement: adım 5, 3 resimden 3.
    • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
    FixBot'a Sor
    Yorum Ekle
  6. Sony a7 AV Port Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the blunt tweezers, remove the blue ribbon cable.
    • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
    FixBot'a Sor
    Yorum Ekle
  7. Sony a7 AV Port Replacement: adım 7, 2 resimden 1. Sony a7 AV Port Replacement: adım 7, 2 resimden 2.
    • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
    FixBot'a Sor
    Yorum Ekle
  8. Sony a7 AV Port Replacement: adım 8, 3 resimden 1. Sony a7 AV Port Replacement: adım 8, 3 resimden 2. Sony a7 AV Port Replacement: adım 8, 3 resimden 3.
    • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Sony a7 AV Port Replacement: adım 9, 1 resimden 1.
    • Lift the metal plate and LCD screen away from the camera body.
    FixBot'a Sor
    Yorum Ekle
  10. Sony a7 AV Port Replacement: adım 10, 1 resimden 1.
    • Detach the amber ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Sony a7 AV Port Replacement, Motherboard: adım 11, 2 resimden 1. Sony a7 AV Port Replacement, Motherboard: adım 11, 2 resimden 2.
    • Peel off the small adhesive tape located on the top right side of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  12. Sony a7 AV Port Replacement: adım 12, 2 resimden 1. Sony a7 AV Port Replacement: adım 12, 2 resimden 2.
    • Remove the exposed ribbon cable by using the iFixit opening tools
    FixBot'a Sor
    Yorum Ekle
  13. Sony a7 AV Port Replacement: adım 13, 1 resimden 1.
    • Peel off the large black protective adhesive from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. Sony a7 AV Port Replacement: adım 14, 2 resimden 1. Sony a7 AV Port Replacement: adım 14, 2 resimden 2.
    • Remove the four visible ribbon cables by using the spudger.
    • Removing the ribbon cables will require lifting a lever located on the connecter in order to pull out the cable.
    FixBot'a Sor
    Yorum Ekle
  15. Sony a7 AV Port Replacement: adım 15, 3 resimden 1. Sony a7 AV Port Replacement: adım 15, 3 resimden 2. Sony a7 AV Port Replacement: adım 15, 3 resimden 3.
    • Remove the one U.FL plug by using the spudger.
    • Using the spudger, remove the four remaining ribbon cables.
    • These ribbon cables do not have the requirement to lift a lever on the connector as specified in previous steps.
    FixBot'a Sor
    Yorum Ekle
  16. Sony a7 AV Port Replacement: adım 16, 1 resimden 1.
    • Remove one M1.5x2mm screw with a PH00 Phillips screwdriver.
    • Remove one coarse threaded 5mm screw with a PH00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  17. Sony a7 AV Port Replacement: adım 17, 3 resimden 1. Sony a7 AV Port Replacement: adım 17, 3 resimden 2. Sony a7 AV Port Replacement: adım 17, 3 resimden 3.
    • Lift the motherboard from the camera body.
    • It helps to pick up the right side of the board first, and then work sequentially down the board. Be sure to gently ease the motherboard from its clips down the remainder of the side.
    • Exercise extreme caution when removing the motherboard as it can be fragile, and damage to it could mean the camera will become unrecoverable.
    FixBot'a Sor
    Yorum Ekle
  18. Sony a7 AV Port Replacement: adım 18, 1 resimden 1.
    • Remove the two visible ribbon cables by using the forceps.
    FixBot'a Sor
    Yorum Ekle
  19. Sony a7 AV Port Replacement, AV Port: adım 19, 2 resimden 1. Sony a7 AV Port Replacement, AV Port: adım 19, 2 resimden 2.
    • Take a soldering iron and place it onto a leg of the failed AV port.
    • Use a small flat head screwdriver to pry up each leg while the solder is molten.
    • The soldering iron and solder will be hot, exercise extreme caution when handling.
    • Always wear eye protection when soldering connections, solder can splatter and cause burns.
    • Do not inhale any smoke or fumes that may be given off during the soldering process, as they can be toxic.
    • For help and tips on how to effectively solder like a professional, please reference the iFixit guide on soldering here.
    FixBot'a Sor
    Yorum Ekle
  20. Sony a7 AV Port Replacement: adım 20, 1 resimden 1.
    • Repeat the actions in the previous step to the remaining three legs of the faulty AV port until the connector is able to be moved, and is free.
    • All of the tips and cautions about the soldering process still apply in this step, continue to exercise extreme due diligence and caution.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 52
Her zaman: 2,769
