Ana içeriğe geç
Steam Controller (2nd Gen, 2026) Buttons Replacement
Neye ihtiyacın var
  1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Before you begin: adım 1, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Before you begin: adım 1, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Before you begin: adım 1, 3 resimden 3.
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    FixBot'a Sor
  2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the back cover screws: adım 2, 2 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the back cover screws: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    TR6 Torx Security Screwdriver
    $5.99
    FixBot'a Sor
  3. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the back cover: adım 3, 2 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the back cover: adım 3, 2 resimden 2.
    • Remove the back cover.
    FixBot'a Sor
  4. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the battery: adım 4, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the battery: adım 4, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the battery: adım 4, 3 resimden 3.
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    FixBot'a Sor
  5. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the mounting bracket screws: adım 5, 2 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the mounting bracket screws: adım 5, 2 resimden 2.
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    FixBot'a Sor
  6. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the mounting bracket: adım 6, 2 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the mounting bracket: adım 6, 2 resimden 2.
    FixBot'a Sor
  7. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the rumble motors: adım 7, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the rumble motors: adım 7, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the rumble motors: adım 7, 3 resimden 3.
    • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
    • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
    • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
    FixBot'a Sor
  8. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 8, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 8, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 8, 3 resimden 3.
    • Repeat to disconnect the other rumble motor.
    FixBot'a Sor
  9. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 3.
    • Be careful not to damage any of the small, surface-mounted components on the main board.
    • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
    FixBot'a Sor
  10. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 10, 2 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 10, 2 resimden 2.
    • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
    FixBot'a Sor
  11. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board screws: adım 11, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board screws: adım 11, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board screws: adım 11, 3 resimden 3.
    • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
    • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
    FixBot'a Sor
  12. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board: adım 12, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board: adım 12, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board: adım 12, 3 resimden 3.
    • Pull the main board down so the top corners clear the triggers.
    • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
    • Remove the main board, guiding the thumbsticks through their cutouts.
    • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
    FixBot'a Sor
  13. Steam Controller (2nd Gen, 2026) Buttons Replacement, Rubber piece information: adım 13, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Rubber piece information: adım 13, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Rubber piece information: adım 13, 3 resimden 3.
    • The rubber piece above the status LED may have been dislodged when removing the main board.
    • If the rubber piece is out of place, remove it and set it aside.
    • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
    FixBot'a Sor
  14. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the hinge pin: adım 14, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the hinge pin: adım 14, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the hinge pin: adım 14, 3 resimden 3.
    • With one hand, hold one of the triggers down in the fully actuated position.
    • Don't let go of the trigger, or it will eject and you may lose its spring.
    • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
    • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
    • When correctly inserted, the pin's end will be aligned with the white rectangle on the board (labelled PIN)—the should be no wobble.
    FixBot'a Sor
  15. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the trigger: adım 15, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the trigger: adım 15, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the trigger: adım 15, 3 resimden 3.
    • Lift the trigger straight up and remove it.
    • Remove the spring and store it in a safe place for reassembly.
    • The spring will either stick to the trigger's magnet or stay on its post.
    FixBot'a Sor
  16. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the other trigger: adım 16, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the other trigger: adım 16, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the other trigger: adım 16, 3 resimden 3.
    • Repeat to remove the other trigger.
    FixBot'a Sor
  17. Steam Controller (2nd Gen, 2026) Buttons Replacement, Reassembly information: adım 17, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Reassembly information: adım 17, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Reassembly information: adım 17, 3 resimden 3.
    • During reassembly, follow this step to install the triggers.
    • Place one of the trigger springs over its post on the controller.
    • Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
    • Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
    • If you're having trouble, make sure you're installing the trigger on the correct side.
    • Test the trigger to ensure the pin was properly installed.
    • Repeat to install the other trigger.
    FixBot'a Sor
  18. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe screws: adım 18, 2 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe screws: adım 18, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
    • When removing the screw in the center of the controller, be careful not to damage the plastic button membrane.
    FixBot'a Sor
  19. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe: adım 19, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe: adım 19, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe: adım 19, 3 resimden 3.
    • Lift the midframe straight up and remove it.
    • The buttons and their silicone pads are now sitting loose in their recesses. Be very careful not to flip the front shell, or the buttons will fall out.
    • During reassembly:
    • Check the two large silicone button pads to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
    • Use the alignment posts to ensure the midframe is in the right position.
    FixBot'a Sor
  20. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the button membranes: adım 20, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the button membranes: adım 20, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the button membranes: adım 20, 3 resimden 3.
    • Remove the three silicone button membranes.
    FixBot'a Sor
  21. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the buttons: adım 21, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the buttons: adım 21, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the buttons: adım 21, 3 resimden 3.
    • Use tweezers to remove the D‑Pad, View, Steam, Menu, and ABXY buttons.
    • Alternatively, you can flip the front case over and let the buttons fall out.
    • To replace the Quick Access Menu button, you'll need to remove the remaining board attached to the front shell. Check out this guide to do so.
    • During reassembly, use the alignment tabs to orient each button in its recess. Each one is keyed specifically for its recess and proper orientation.
    FixBot'a Sor
  22. Steam Controller (2nd Gen, 2026) Buttons Replacement, Seat the button dampeners: adım 22, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Seat the button dampeners: adım 22, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Seat the button dampeners: adım 22, 3 resimden 3.
    • Make sure the button dampeners (that surround the button recesses) are pushed down and fully seated against the shell. Otherwise, button presses may feel off or not register.
    FixBot'a Sor
  23. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the touchpad cables: adım 23, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the touchpad cables: adım 23, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the touchpad cables: adım 23, 3 resimden 3.
    • Use the flat end of a spudger to lift the hinged, locking flap on one of the touchpad ZIF connectors.
    FixBot'a Sor
  24. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 24, 2 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 24, 2 resimden 2.
    FixBot'a Sor
  25. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 25, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 25, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement: adım 25, 3 resimden 3.
    • Repeat to disconnect the other touchpad cable.
    FixBot'a Sor
  26. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board screws: adım 26, 2 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board screws: adım 26, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the FSC board.
    FixBot'a Sor
  27. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board: adım 27, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board: adım 27, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board: adım 27, 3 resimden 3.
    • Remove the FSC board.
    • Use the alignment pegs to ensure the board is correctly positioned.
    FixBot'a Sor
  28. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the Quick Access Menu button: adım 28, 3 resimden 1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the Quick Access Menu button: adım 28, 3 resimden 2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the Quick Access Menu button: adım 28, 3 resimden 3.
    • Remove the Quick Access Menu membrane and button.
    • During reassembly, make sure the silicone button dampener (it surrounds the button recess) is fully pushed down and seated against the shell.
    FixBot'a Sor
Sonuç
Spencer Day
187.948 İtibar
1.187 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 140
Son 30 gün: 1,006
Her zaman: 1,031
