Ana içeriğe geç
Steam Controller (2nd Gen, 2026) Left Trackpad Replacement
Neye ihtiyacın var
  1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Before you begin: adım 1, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Before you begin: adım 1, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Before you begin: adım 1, 3 resimden 3.
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    FixBot'a Sor
    Yorum Ekle
  2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the back cover screws: adım 2, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the back cover screws: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    TR6 Torx Security Screwdriver
    $5.99
    FixBot'a Sor
    Yorum Ekle
  3. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the back cover: adım 3, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the back cover: adım 3, 2 resimden 2.
    • Remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  4. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the battery: adım 4, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the battery: adım 4, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the battery: adım 4, 3 resimden 3.
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    FixBot'a Sor
    Yorum Ekle
  5. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the mounting bracket screws: adım 5, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the mounting bracket screws: adım 5, 2 resimden 2.
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    FixBot'a Sor
    Yorum Ekle
  6. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the mounting bracket: adım 6, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the mounting bracket: adım 6, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  7. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the rumble motors: adım 7, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the rumble motors: adım 7, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the rumble motors: adım 7, 3 resimden 3.
    • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
    • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
    • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
    FixBot'a Sor
    Yorum Ekle
  8. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 8, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 8, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 8, 3 resimden 3.
    • Repeat to disconnect the other rumble motor.
    FixBot'a Sor
    Yorum Ekle
  9. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 3.
    • Be careful not to damage any of the small, surface-mounted components on the main board.
    • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
    FixBot'a Sor
    Yorum Ekle
  10. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 10, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 10, 2 resimden 2.
    • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
    FixBot'a Sor
    Yorum Ekle
  11. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board screws: adım 11, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board screws: adım 11, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board screws: adım 11, 3 resimden 3.
    • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
    • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
    FixBot'a Sor
    Yorum Ekle
  12. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board: adım 12, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board: adım 12, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the main board: adım 12, 3 resimden 3.
    • Pull the main board down so the top corners clear the triggers.
    • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
    • Remove the main board, guiding the thumbsticks through their cutouts.
    • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
    FixBot'a Sor
    Yorum Ekle
  13. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Rubber piece information: adım 13, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Rubber piece information: adım 13, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Rubber piece information: adım 13, 3 resimden 3.
    • The rubber piece above the status LED may have been dislodged when removing the main board.
    • If the rubber piece is out of place, remove it and set it aside.
    • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
    FixBot'a Sor
    Yorum Ekle
  14. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the hinge pin: adım 14, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the hinge pin: adım 14, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the hinge pin: adım 14, 3 resimden 3.
    • With one hand, fully depress one trigger.
    • Don't let go of the trigger, or it will eject and you may lose its spring.
    • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
    • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
    • When correctly inserted, the pin's end will be alinged with the white rectangle on the board (labeled PIN)—there should be no wobble.
    FixBot'a Sor
    Yorum Ekle
  15. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trigger: adım 15, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trigger: adım 15, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trigger: adım 15, 3 resimden 3.
    • Lift the trigger straight up and remove it.
    • Remove the spring and store it in a safe place for reassembly.
    • The spring will either stick to the trigger's magnet or stay on its post.
    FixBot'a Sor
    Yorum Ekle
  16. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the other trigger: adım 16, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the other trigger: adım 16, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the other trigger: adım 16, 3 resimden 3.
    • Repeat to remove the other trigger.
    FixBot'a Sor
    Yorum Ekle
  17. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Reassembly information: adım 17, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Reassembly information: adım 17, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Reassembly information: adım 17, 3 resimden 3.
    • During reassembly, follow this step to install the triggers.
    • Place one of the trigger springs over its post on the controller.
    • Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
    • Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
    • If you're having trouble, make sure you're installing the trigger on the correct side.
    • Test the trigger to ensure the pin was properly installed.
    • Repeat to install the other trigger.
    FixBot'a Sor
    Yorum Ekle
  18. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe screws: adım 18, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe screws: adım 18, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
    • When removing the screw in the center of the controller, be careful not to slip and damage the flexible button circuit.
    FixBot'a Sor
    Yorum Ekle
  19. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe: adım 19, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe: adım 19, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the midframe: adım 19, 3 resimden 3.
    • Lift the midframe straight up and remove it.
    • The buttons and their silicone membranes are now sitting loose in their recesses. Don't flip the front shell or the buttons will fall out. Optionally, remove the membranes and buttons and set them aside.
    • During reassembly:
    • If you removed the buttons and their membranes:
    • Make sure the rubber button dampeners (that surround the button recesses) are pushed down and fully seated against the shell.
    • Install the buttons and membranes, using the alignment tabs to orient each button in its recess. Each one is keyed for proper location and orientation.
    • Check the two large silicone button membranes to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
    • Use the alignment posts to ensure the midframe is in the right position.
    FixBot'a Sor
    Yorum Ekle
  20. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Check for the Steam button membrane: adım 20, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Check for the Steam button membrane: adım 20, 2 resimden 2.
    • Check if the Steam button's silicone membrane stuck to the button circuit on the midframe.
    • If it did, either put the membrane back in place or set it aside.
    FixBot'a Sor
    Yorum Ekle
  21. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the trackpad cables: adım 21, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Disconnect the trackpad cables: adım 21, 2 resimden 2.
    • Use the flat end of a spudger to lift the hinged, locking flap on one of the trackpad ZIF connectors.
    FixBot'a Sor
    Yorum Ekle
  22. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 22, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 22, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  23. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 23, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 23, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement: adım 23, 3 resimden 3.
    • Repeat to disconnect the other trackpad cable.
    FixBot'a Sor
    Yorum Ekle
  24. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board screws: adım 24, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board screws: adım 24, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the FSC board.
    FixBot'a Sor
    Yorum Ekle
  25. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board: adım 25, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board: adım 25, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the FSC board: adım 25, 3 resimden 3.
    • Remove the FSC board.
    • Use the alignment pegs to ensure the board is correctly positioned.
    FixBot'a Sor
    Yorum Ekle
  26. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad screws: adım 26, 3 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad screws: adım 26, 3 resimden 2. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad screws: adım 26, 3 resimden 3.
    • The left trackpad will be on your right-hand side, as the shell is upside down.
    • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the left trackpad.
    • When reinstalling the screws, raise the controller so the trackpad isn't pressed against your work surface. Don't lift too high, or the buttons may fall out.
    FixBot'a Sor
    Yorum Ekle
  27. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad: adım 27, 2 resimden 1. Steam Controller (2nd Gen, 2026) Left Trackpad Replacement, Remove the trackpad: adım 27, 2 resimden 2.
    • Remove the trackpad.
    • During reassembly, set the trackpad into its cutout so the cable is on the bottom edge. Make sure all the alignment tabs and posts go through their cutouts by the screw holes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Spencer Day
194.638 İtibar
1.243 adet Kılavuz yazıldı
2Kılavuz Yorumları
I don’t own one, so I’d like to ask: ⏎
Does this touchpad have a mechanism that allows it to be physically pressed? ⏎
Also, do you know what kind of LRA is used for the haptic feedback?
Satoshi S - Yanıt Paylaş
^ I also do not own one but I do have a Steam Deck with a broken touchpad. Out of curiousity, does this have the same crap as that, where the part needs "special calibration" or whatever and you can only find parts second hand that may work?
Tyler - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 46
Son 30 gün: 157
Her zaman: 728
