Giriş
Use this guide to replace the left touchpad on your Steam Deck LCD. The touchpad itself is part of a larger module—including haptics—and needs to be replaced as one unit. Although similar, the procedure for the right touchpad can be found here.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
Note: The touchpad's springs are very delicate and are precisely positioned. If bent, the touchpad may rattle or not work as intended.
These steps only describe how to physically remove and replace your console’s touchpad. You may need additional software tools and calibration procedures to get the replacement touchpad to function as intended.
Neye ihtiyacın var
Power down your Steam Deck and unplug any cables.
Bu adımda kullanılan alet:FixMat$36.95
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Place the flat end of a spudger onto the inside edge of the trigger's left clip.
Pivot the trigger clip out, away, and up from the peg to unlatch it.
Use a Phillips driver to remove the three 5.2 mm screws securing the left trigger bracket.
Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
Use a pair of tweezers to slide the cable out of its connector.
Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
If any connectors are covered with tape, use a pair of tweezers to remove it.
Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
Disconnect the D-pad cable.
Disconnect the touchpad board cable.
Disconnect the touchpad cable.
Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
Use a Phillips driver to disconnect the four screws securing the left button board:
Three 5.2 mm screws
One 3.9 mm screw
Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad board.
Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad.
From the front of the Steam Deck, use your finger to push the left touchpad partway through the front shell to unseat it.
Lift the touchpad out from underneath the overhanging section of the midframe.
Remove the touchpad.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
10Kılavuz Yorumları
I, too, would like to know where we can obtain replacement touchpads.
Yeah where are the replacement touch pads? My left pad is stuck and clicky.
