Ana içeriğe geç
Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
Neye ihtiyacın var
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: adım 1, 3 resimden 1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: adım 1, 3 resimden 2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: adım 1, 3 resimden 3.
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: adım 2, 1 resimden 1.
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: adım 4, 3 resimden 1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: adım 4, 3 resimden 2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: adım 4, 3 resimden 3.
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: adım 5, 1 resimden 1.
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: adım 6, 1 resimden 1.
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 499
