Ana içeriğe geç
Switch Pro Controller Motherboard Replacement
Neye ihtiyacın var
  1. Switch Pro Controller Motherboard Replacement, Remove the screws: adım 1, 1 resimden 1.
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
  2. Switch Pro Controller Motherboard Replacement, Remove the handle covers: adım 2, 3 resimden 1. Switch Pro Controller Motherboard Replacement, Remove the handle covers: adım 2, 3 resimden 2. Switch Pro Controller Motherboard Replacement, Remove the handle covers: adım 2, 3 resimden 3.
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Switch Pro Controller Motherboard Replacement, Remove the screws: adım 3, 1 resimden 1.
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Switch Pro Controller Motherboard Replacement, Unclip the plastic cover: adım 4, 3 resimden 1. Switch Pro Controller Motherboard Replacement, Unclip the plastic cover: adım 4, 3 resimden 2. Switch Pro Controller Motherboard Replacement, Unclip the plastic cover: adım 4, 3 resimden 3.
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Switch Pro Controller Motherboard Replacement, Remove the clear plastic cover: adım 5, 1 resimden 1.
    • Remove the clear plastic cover.
  6. Switch Pro Controller Motherboard Replacement, Remove the battery: adım 6, 3 resimden 1. Switch Pro Controller Motherboard Replacement, Remove the battery: adım 6, 3 resimden 2. Switch Pro Controller Motherboard Replacement, Remove the battery: adım 6, 3 resimden 3.
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
  7. Switch Pro Controller Motherboard Replacement, Remove the screws: adım 7, 3 resimden 1. Switch Pro Controller Motherboard Replacement, Remove the screws: adım 7, 3 resimden 2. Switch Pro Controller Motherboard Replacement, Remove the screws: adım 7, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
  8. Switch Pro Controller Motherboard Replacement: adım 8, 3 resimden 1. Switch Pro Controller Motherboard Replacement: adım 8, 3 resimden 2. Switch Pro Controller Motherboard Replacement: adım 8, 3 resimden 3.
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
  9. Switch Pro Controller Motherboard Replacement, Open the flap: adım 9, 2 resimden 1. Switch Pro Controller Motherboard Replacement, Open the flap: adım 9, 2 resimden 2.
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
  10. Switch Pro Controller Motherboard Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 1. Switch Pro Controller Motherboard Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
  11. Switch Pro Controller Motherboard Replacement, Remove the front case: adım 11, 1 resimden 1.
    • Remove the front case.
  12. Switch Pro Controller Motherboard Replacement, Remove the joystick caps: adım 12, 3 resimden 1. Switch Pro Controller Motherboard Replacement, Remove the joystick caps: adım 12, 3 resimden 2. Switch Pro Controller Motherboard Replacement, Remove the joystick caps: adım 12, 3 resimden 3.
    • With light force pull the two joystick caps off of the controller.
  13. Switch Pro Controller Motherboard Replacement, Loosen the adhesive: adım 13, 2 resimden 1. Switch Pro Controller Motherboard Replacement, Loosen the adhesive: adım 13, 2 resimden 2.
    • Insert the tip of a spudger from the back into the hole on the right controller handle.
    • Push the spudger through the hole to loosen the adhesive which is holding rumble modules in their places.
  14. Switch Pro Controller Motherboard Replacement, Loosen the adhesive: adım 14, 2 resimden 1. Switch Pro Controller Motherboard Replacement, Loosen the adhesive: adım 14, 2 resimden 2.
    • Insert the tip of a spudger from the back into the hole on the left controller handle.
  15. Switch Pro Controller Motherboard Replacement, Lift the modules: adım 15, 2 resimden 1. Switch Pro Controller Motherboard Replacement, Lift the modules: adım 15, 2 resimden 2.
    • Use a pair tweezers to lift the modules out of their places.
  16. Switch Pro Controller Motherboard Replacement, Unscrew the motherboard: adım 16, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 5 mm-long screws securing the motherboard.
  17. Switch Pro Controller Motherboard Replacement, Remove the LED light: adım 17, 3 resimden 1. Switch Pro Controller Motherboard Replacement, Remove the LED light: adım 17, 3 resimden 2. Switch Pro Controller Motherboard Replacement, Remove the LED light: adım 17, 3 resimden 3.
    • Use your thumb or a pair of tweezers to to take off the white LED light housing.
  18. Switch Pro Controller Motherboard Replacement, Lift the motherboard: adım 18, 3 resimden 1. Switch Pro Controller Motherboard Replacement, Lift the motherboard: adım 18, 3 resimden 2. Switch Pro Controller Motherboard Replacement, Lift the motherboard: adım 18, 3 resimden 3.
    • Lift the motherboard carefully as to not damage the wires and flip it to reveal the backside.
  19. Switch Pro Controller Motherboard Replacement, Desolder the rumble modules: adım 19, 3 resimden 1. Switch Pro Controller Motherboard Replacement, Desolder the rumble modules: adım 19, 3 resimden 2. Switch Pro Controller Motherboard Replacement, Desolder the rumble modules: adım 19, 3 resimden 3.
    • Desolder the rumble motor solder points on either side of the motherboard.
    • Remove the rumble modules.
    • Refer to the following solder guide if necessary: How to Solder
    • Solder the new rumble modules into the same pins.
  20. Switch Pro Controller Motherboard Replacement, Desolder the main power cable: adım 20, 2 resimden 1. Switch Pro Controller Motherboard Replacement, Desolder the main power cable: adım 20, 2 resimden 2.
    • Remove the main power cable from the highlighted pins by de-soldering them.
    • Remove the motherboard.
    • Refer to the following solder guide if necessary: How to Solder.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
maybe a tutorial about how you change the usb c port since there are no videos about the pro controller replacement anywhere
Del Meg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 114
Son 30 gün: 443
Her zaman: 22,200
