Ana içeriğe geç
Syma S107 Gyro Replacement
Neye ihtiyacın var
  1. Syma S107 Gyro Replacement, Counterweight Bar: adım 1, 2 resimden 1. Syma S107 Gyro Replacement, Counterweight Bar: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
  2. Syma S107 Gyro Replacement: adım 2, 2 resimden 1. Syma S107 Gyro Replacement: adım 2, 2 resimden 2.
    • Remove the counterweight bar by removing the screw.
    • One 10.1mm Phillips #0.
  3. Syma S107 Gyro Replacement, Gyro Carriage: adım 3, 2 resimden 1. Syma S107 Gyro Replacement, Gyro Carriage: adım 3, 2 resimden 2.
    • Remove the gyro carriage by removing the following screws:
    • Two 5.6mm Phillips #0.
    • When reinstalling these screws make sure to line up one screw with the keyway on the main rotor shaft.
  4. Syma S107 Gyro Replacement: adım 4, 2 resimden 1. Syma S107 Gyro Replacement: adım 4, 2 resimden 2.
    • Gently remove the broken gyro carriage by pulling up.
    • Remove blade assembly by simply sliding it up and off the shaft.
  5. Syma S107 Gyro Replacement, Blade Carriage: adım 5, 3 resimden 1. Syma S107 Gyro Replacement, Blade Carriage: adım 5, 3 resimden 2. Syma S107 Gyro Replacement, Blade Carriage: adım 5, 3 resimden 3.
    • Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
  6. Syma S107 Gyro Replacement: adım 6, 2 resimden 1. Syma S107 Gyro Replacement: adım 6, 2 resimden 2.
    • Remove the blades from the blade carriage by removing the following screws:
    • Two 4.7mm Phillips #0.
  7. Syma S107 Gyro Replacement: adım 7, 2 resimden 1. Syma S107 Gyro Replacement: adım 7, 2 resimden 2.
    • Remove the following screws:
    • Two 4.5mm Phillips #0.
    • Make sure to remove any broken plastic pins before reassembling the components.
    • You will have to slide the two halves of the blade carriage over the pins on the gyro carriage first when reassembling.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Christopher Smith
305 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-31, Donnelly Fall 2014 USF Tampa, Team 1-31, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G31
1 Üye
1 Kılavuz yazıldı
6Kılavuz Yorumları
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Patrick haymer - Yanıt
Cheers thanks too this page I fixed problem  great ,  Martin
Martin Worboys - Yanıt
Same here, incidentally where can I get replacement batteries please? Also have a “Picolo” heli with a bad feedback IC , supposedly this part can also be replaced on some units as its a soldered vertical board on the main.
Andre - Yanıt
Thank you! Took forever to find an answer to my problem! Now very obvious thanks to you. My sanity is restored! HaHa!
CRC 04/04/2021
Chris - Yanıt
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Adam Leavesley - Yanıt
Now it flies in an oval pattern wat am I doing wrong?
prober1212 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 54
Her zaman: 14,665
