Ana içeriğe geç
TOZO HT2 Main Board Replacement
Neye ihtiyacın var
  1. TOZO HT2 Main Board Replacement, Ear Pad: adım 1, 3 resimden 1. TOZO HT2 Main Board Replacement, Ear Pad: adım 1, 3 resimden 2. TOZO HT2 Main Board Replacement, Ear Pad: adım 1, 3 resimden 3.
    • Firmly hold the headphone housing in one hand to hold the device steady and put the other hand on the ear pad you intend to replace.
    • Note: Do not force the ear pad to come off or you risk breaking the tabs that keep the pads in place.
  2. TOZO HT2 Main Board Replacement: adım 2, 3 resimden 1. TOZO HT2 Main Board Replacement: adım 2, 3 resimden 2. TOZO HT2 Main Board Replacement: adım 2, 3 resimden 3.
    • Twist the ear cover counterclockwise until it pops off.
    • Repeat for the other ear pad if necessary.
  3. TOZO HT2 Main Board Replacement, Main Board: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove each of the four screws on the speaker cover.
    • Lift the cover off without pulling on the wires inside and set it to the side to access the circuit board.
  4. TOZO HT2 Main Board Replacement: adım 4, 2 resimden 1. TOZO HT2 Main Board Replacement: adım 4, 2 resimden 2.
    • Use a Philips screwdriver to remove the screws that secure the main board.
    • Carefully lift the board out of the headphones, making sure to not pull on and damage the wires inside.
  5. TOZO HT2 Main Board Replacement: adım 5, 1 resimden 1.
    • Use flush cutters to cut the wires as close as possible to their main board connections.
  6. TOZO HT2 Main Board Replacement: adım 6, 1 resimden 1.
    • Soldering how to
    • Use this guide to reattach the wires to the circuit board.
    • HANDLE WITH CARE: Soldering Iron becomes VERY Hot (Up to or above 400°C or 800°F).
    • Wear eye protection while soldering and only do so in a well ventilated room and/or with a fume extractor.
    • Remove all possible fire hazards from the surrounding area.
    • Keep all animals and children out of the room.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Raven M
614 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 289
