Ana içeriğe geç
Tagital T9X Camera Replacement
Adam Bamforth
Adam Bamforth ve 4 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
Tahmin yok
Orta
Eksik önkoşulları
Daha iyi giriş
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Tagital T9X Camera Replacement, Back Cover: adım 1, 1 resimden 1.
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Camera Replacement: adım 2, 1 resimden 1.
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Camera Replacement, Camera: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, carefully remove the cloth covering from the ribbon connector for the camera.
  4. Tagital T9X Camera Replacement: adım 4, 1 resimden 1.
    • Use the tip of the spudger or your fingernail to flip up the small flap on the ZIF connector.
    • Carefully remove the ribbon cable from the connector.
  5. Tagital T9X Camera Replacement: adım 5, 1 resimden 1.
    • Remove the camera from its position at the top of the tablet.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 172
