Ana içeriğe geç
ThinkPad Edge E31 Underside Disassembly
Riley
Riley ve 4 diğer katkıda bulunanlar
En son May 10, 2017 tarihinde güncellendi
2 dakika
Çok kolay
This disassembly guide is to remove the back of the laptop to expose commonly replaced and upgraded components of the laptop.
Neye ihtiyacın var
  1. ThinkPad Edge E31 Underside Disassembly, Battery: adım 1, 1 resimden 1.
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
  2. ThinkPad Edge E31 Underside Disassembly: adım 2, 1 resimden 1.
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
  3. ThinkPad Edge E31 Underside Disassembly, ThinkPad Edge E31 Underside Disassembly: adım 3, 1 resimden 1.
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
Sonuç
Riley
601 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 363
