Ana içeriğe geç
TiVo Series 2 TCD540080 Hard Drive Replacement
Svyatoslav Markeyev
Svyatoslav Markeyev ve 5 diğer katkıda bulunanlar
En son January 28, 2014 tarihinde güncellendi
10 dakika
Kolay
Neye ihtiyacın var
Aletler
  1. TiVo Series 2 TCD540080 Hard Drive Replacement, Removal of TiVo Series 2 TCD540080 Case: adım 1, 1 resimden 1.
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Hard Drive Replacement: adım 3, 2 resimden 1. TiVo Series 2 TCD540080 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Disconnect the power to the hard drive.
  5. TiVo Series 2 TCD540080 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Grab the hard drive data cable from both sides of the connector and unplug it from the hard drive.
    • Use extreme caution when unplugging connector and do not disconnect the data cable by pulling on the cable itself.
  6. TiVo Series 2 TCD540080 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Unscrew the two screws on the case of the hard drive with a T10 screwdriver.
    • Pull the hard drive up and out of the TiVo unit.
  7. TiVo Series 2 TCD540080 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Unscrew the four screws, shown in the picture, with a T-10 screwdriver.
    • Remove the hard drive from the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Svyatoslav Markeyev
135 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G79
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 7,726
