Ana içeriğe geç
Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement
Carsten Frauenheim
Carsten Frauenheim
En son December 29, 2020 tarihinde güncellendi
Tahmin yok
Orta
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Prerequisite only! This guide shows how to remove and replace the control valve bracket on the Toro Log Splitter 22618HD 2019 / LS-922.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Disconnect the spark plug wire: adım 1, 2 resimden 1. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Disconnect the spark plug wire: adım 1, 2 resimden 2.
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Flip the engine switch to the off position: adım 2, 2 resimden 1. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Flip the engine switch to the off position: adım 2, 2 resimden 2.
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Close the fuel valve: adım 3, 2 resimden 1. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Close the fuel valve: adım 3, 2 resimden 2.
    • Flip the fuel valve lever to the OFF position.
  4. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Remove the control valve bracket bolts: adım 4, 1 resimden 1.
    • Use a 3/8 inch socket to remove the three bolts securing the control valve to the control valve bracket.
  5. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement: adım 5, 1 resimden 1.
    • Use a 9/16 inch socket to remove the two bolts securing the control valve bracket to the frame.
  6. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Remove the control valve bracket: adım 6, 2 resimden 1. Toro Log Splitters 22618HD 2019 Control Valve Bracket Replacement, Remove the control valve bracket: adım 6, 2 resimden 2.
    • Remove the control valve bracket.
Sonuç
Carsten Frauenheim
136.935 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.670 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 21
