Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement
Giriş
1. adıma gitAfter diagnosing your Toshiba Satellite A105-S4074, should you conclude that the optical disk drive has failed and will need to be replaced, these easy to follow instructions will guide you through the process.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Turn the laptop around with the battery slot facing away from you.
Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
