Ana içeriğe geç
Toshiba Satellite A105-S4284 Trackpad Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A105-S4284 Trackpad Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A105-S4284 Trackpad Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  2. Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: adım 2, 3 resimden 1. Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: adım 2, 3 resimden 2. Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: adım 2, 3 resimden 3.
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Toshiba Satellite A105-S4284 Trackpad Replacement: adım 3, 2 resimden 1. Toshiba Satellite A105-S4284 Trackpad Replacement: adım 3, 2 resimden 2.
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  4. Toshiba Satellite A105-S4284 Trackpad Replacement: adım 4, 2 resimden 1. Toshiba Satellite A105-S4284 Trackpad Replacement: adım 4, 2 resimden 2.
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Toshiba Satellite A105-S4284 Trackpad Replacement, Trackpad: adım 5, 1 resimden 1.
    • the upper half of the computer base.
    FixBot'a Sor
    Yorum Ekle
  6. Toshiba Satellite A105-S4284 Trackpad Replacement: adım 6, 2 resimden 1. Toshiba Satellite A105-S4284 Trackpad Replacement: adım 6, 2 resimden 2.
    • Remove the 3 4.5mm screws holding the track-pad in place.
    • There are some screws that will be hidden by assembly tape.
    FixBot'a Sor
    Yorum Ekle
  7. Toshiba Satellite A105-S4284 Trackpad Replacement: adım 7, 1 resimden 1.
    • Slide green circuit board to right and lift track pad free from laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Josh
685 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Cichon Spring 2014 UMass Dartmouth, Team 1-6, Cichon Spring 2014 üyesi
UMASSD-CICHON-S14S1G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 907
