Giriş
Before attempting this guide, please have all required materials and tools. This guide is a long process and requires your full attention in order to properly replace it. When doing each step be careful and follow each step as listed.
Parçalar
Hiçbir parça belirtilmedi.
Slide the battery lock tab away from the center of the laptop to unlock the battery.
Remove the screw holding the RAM cover with a PH1 screwdriver.
Remove the RAM cover.
Use a PH0 screwdriver to remove the screw holding the optical drive in place.
Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
The optical drive will then slide out.
Close the laptop and flip it over.
Unscrew the 11 yellow circled screws with a PH1 screwdriver. These screws are larger in size.
Unscrew the 2 red and yellow circled screws with a PH1 screwdriver. These screws are shorter and thicker than the previous.
Unscrew the 1 green and yellow circled screw with a PH1 screwdriver. This screw is longer and thinner than the previous.
First, remove the one screw with a PH1 screwdriver.
Next, remove the black connector marked by the yellow box.
6 farklı kişi bu kılavuzu tamamladı.
