Ana içeriğe geç
Toshiba Satellite C55-B5200 Keyboard Replacement
Pablo Andrade
Pablo Andrade ve 3 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
10 dakika
Zor
Standard Keyboard with 10-key and touchpad with multi-touch control
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 2, 1 resimden 1.
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 6, 3 resimden 1. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 6, 3 resimden 2. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 6, 3 resimden 3.
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 7, 1 resimden 1.
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite C55-B5200 Keyboard Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Pablo Andrade
1.081 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G1
4 Üyeler
22 adet Kılavuz yazıldı
Bir Yorum
gracias por la guía
Mark Puga - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 4,054
