Ana içeriğe geç
Toshiba Satellite CL15t-B1204X  Speaker Replacement
Royce Alexander Porter
Royce Alexander Porter ve 2 diğer katkıda bulunanlar
En son December 30, 2022 tarihinde güncellendi
10 dakika
Orta
Daha İyi Resimler Gerekli
Daha iyi giriş
Neye ihtiyacın var
Aletler
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X  Speaker Replacement: adım 2, 1 resimden 1.
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X  Speaker Replacement: adım 3, 1 resimden 1.
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X  Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X  Speaker Replacement: adım 5, 1 resimden 1.
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X  Speaker Replacement: adım 6, 1 resimden 1.
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Speaker: adım 7, 2 resimden 1. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Speaker: adım 7, 2 resimden 2.
    • Carefully unplug the speaker's cord from the I/O board.
  8. Toshiba Satellite CL15t-B1204X  Speaker Replacement: adım 8, 2 resimden 1. Toshiba Satellite CL15t-B1204X  Speaker Replacement: adım 8, 2 resimden 2.
    • Unscrew the two 3mm screws with the PH1 screw head on each speaker found on the corner's away from the hinges.
  9. Toshiba Satellite CL15t-B1204X  Speaker Replacement: adım 9, 1 resimden 1.
    • Remove the speakers.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 212
