Ana içeriğe geç
Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement
Matthew Hook
Matthew Hook ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
25 dakika
Orta
This guide will walk you through step by step on how to replace the screen display assembly on a Toshiba Satellite CL15t-b1204x. The screen display is vulnerable to any type of physical damage, whether that be from exposure to liquids or screen crackings. It may also need to be replaced if it stops working after a long period of time. One thing to keep in mind, is that the display comes as a full assembly, and a new assembly can be ordered online.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 2, 1 resimden 1.
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 3, 1 resimden 1.
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 5, 1 resimden 1.
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 6, 1 resimden 1.
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: adım 7, 3 resimden 1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: adım 7, 3 resimden 2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: adım 7, 3 resimden 3.
    • Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
  8. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 8, 3 resimden 1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 8, 3 resimden 2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
  9. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 9, 2 resimden 1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 9, 2 resimden 2.
    • Remove the black webcam connector by pulling backwards with the tweezers.
  10. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 10, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
  11. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 11, 3 resimden 1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 11, 3 resimden 2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 11, 3 resimden 3.
    • Open the laptop and remove the display assembly from the keyboard assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Hook
439 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Hovde Fall 2019 IUPUI, Team S1-G6, Hovde Fall 2019 üyesi
IUPUI-HOVDE-F19S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 309
