Ana içeriğe geç
Toshiba Satellite L35-S2174 Hard Drive Replacement
Amani Mitchell
Amani Mitchell ve 3 diğer katkıda bulunanlar
En son December 21, 2016 tarihinde güncellendi
1 - 4 dakika
Kolay
The hard drive is the memory center of your computer. It stores all of your information and files and allows you able to access that data. Replacing the hard drive can speed up your computer and improve the hard drive storage space.
Neye ihtiyacın var
  1. Toshiba Satellite L35-S2174 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite L35-S2174 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite L35-S2174 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Hard Drive Replacement: adım 4, 1 resimden 1.
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 1. Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 2. Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 3.
    • Use a J1 screwdriver to unscrew the two circled screws. The screws will remain attached to the plastic panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite L35-S2174 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Slide the hard drive to the left to detach it from the computer.
    • Lift the hard drive from the computer.
Sonuç
Amani Mitchell
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Catania Fall 2016 UMass Dartmouth, Team 1-4, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G4
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 600
