Ana içeriğe geç
Toshiba Satellite L505D-GS6000 Disk Drive Replacement
Adam Dellicker
Adam Dellicker ve başka bir katkıda bulunan
En son June 5, 2018 tarihinde güncellendi
1 - 2 dakika
Kolay
This guide is to be used if your disk drive is not operational and needs to be replaced.
You should replace your disk drive if it isn’t able to read something and you tried other methods of fixing it, or if the disk drive itself won’t open.
The process is fairly simple and will only require removal of one screw.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: adım 2, 1 resimden 1.
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: adım 3, 1 resimden 1.
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: adım 4, 1 resimden 1.
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam Dellicker
539 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G2
2 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 393
