Ana içeriğe geç
Toshiba Satellite L505D-GS6000 Key Replacement
Adam Dellicker
Adam Dellicker ve başka bir katkıda bulunan
En son June 5, 2018 tarihinde güncellendi
15 - 30 saniye
Çok kolay
This guide should be used if a key is loose on the keyboard or a key isn’t working as intended.
The process should not require any tools, but a plastic opening tool may make it a little easier.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite L505D-GS6000 Key Replacement, Key: adım 1, 3 resimden 1. Toshiba Satellite L505D-GS6000 Key Replacement, Key: adım 1, 3 resimden 2. Toshiba Satellite L505D-GS6000 Key Replacement, Key: adım 1, 3 resimden 3.
    • Open laptop in the front facing position.
    • Use a plastic opening tool to remove the desired key from the keyboard.
    • When lifting up on the key, do so carefully as to not break the key or its housing underneath.
  2. Toshiba Satellite L505D-GS6000 Key Replacement: adım 2, 1 resimden 1.
    • Use a finger to push a new key into place.
Sonuç
If the key does not feel like it feels to be in the correct position, retry the process following the steps in order again.
Adam Dellicker
539 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G2
2 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 459
