Ana içeriğe geç
Toshiba Satellite L55-A Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L55-A Battery Replacement, Remove the RAM cover: adım 1, 1 resimden 1.
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite L55-A Battery Replacement: adım 2, 2 resimden 2.
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: adım 3, 3 resimden 1. Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: adım 3, 3 resimden 2. Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: adım 3, 3 resimden 3.
    • Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
    • Disconnect the cable.
    • During reassembly, make sure you re-insert this connector right-side-up. The connector is keyed to plug in only one orientation, so if it doesn't slide into place easily, turn it around and try the other way.
  4. Toshiba Satellite L55-A Battery Replacement, Remove the back cover: adım 4, 1 resimden 1.
    • Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
  5. Toshiba Satellite L55-A Battery Replacement: adım 5, 3 resimden 1. Toshiba Satellite L55-A Battery Replacement: adım 5, 3 resimden 2. Toshiba Satellite L55-A Battery Replacement: adım 5, 3 resimden 3.
    • Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
    • Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
    • Slide the drive out of the bay and remove it from the laptop.
  6. Toshiba Satellite L55-A Battery Replacement: adım 6, 2 resimden 1. Toshiba Satellite L55-A Battery Replacement: adım 6, 2 resimden 2.
    • The back cover is still held in place by plastic clips.
    • Insert the point of an opening pick into the back cover seam near the ethernet port.
    • Twist the pick to release the plastic clips along the edge.
  7. Toshiba Satellite L55-A Battery Replacement: adım 7, 3 resimden 1. Toshiba Satellite L55-A Battery Replacement: adım 7, 3 resimden 2. Toshiba Satellite L55-A Battery Replacement: adım 7, 3 resimden 3.
    • Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
    • If you meet significant resistance, stop and check for forgotten screws.
    • Remove the back cover.
    • To reinstall the back cover, align the cover and press along the edges to snap the clips back in place.
  8. Toshiba Satellite L55-A Battery Replacement, Unscrew the battery: adım 8, 1 resimden 1.
    • Remove the two 6.8 mm long Phillips screws securing the battery.
  9. Toshiba Satellite L55-A Battery Replacement: adım 9, 2 resimden 1. Toshiba Satellite L55-A Battery Replacement: adım 9, 2 resimden 2.
    • Lift the battery out of its recess and move it slightly away from the motherboard in order to reveal the battery cable.
  10. Toshiba Satellite L55-A Battery Replacement, Disconnect the battery: adım 10, 2 resimden 1. Toshiba Satellite L55-A Battery Replacement, Disconnect the battery: adım 10, 2 resimden 2.
    • Grasp the battery cable near its motherboard socket and pull the connector horizontally out of the socket.
  11. Toshiba Satellite L55-A Battery Replacement, Remove the battery: adım 11, 1 resimden 1.
    • Remove the battery.
Sonuç
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Arthur Shi
283.247 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.623 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,761
