Ana içeriğe geç
Toshiba Satellite L855-S5119 Charger Port Replacement
Tyler Shafer
Tyler Shafer ve 3 diğer katkıda bulunanlar
En son June 11, 2023 tarihinde güncellendi
15 dakika
Orta
This guide will help you gain access to and replace the DC powerport,
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite L855-S5119 Charger Port Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 2, 3 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 2, 3 resimden 2. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 2, 3 resimden 3.
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 3, 2 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 3, 2 resimden 2.
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Charger Port Replacement, Back Plate Removal: adım 4, 3 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement, Back Plate Removal: adım 4, 3 resimden 2. Toshiba Satellite L855-S5119 Charger Port Replacement, Back Plate Removal: adım 4, 3 resimden 3.
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Charger Port Replacement, Optical Drive: adım 5, 2 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement, Optical Drive: adım 5, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  6. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 6, 2 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 6, 2 resimden 2.
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
  7. Toshiba Satellite L855-S5119 Charger Port Replacement, Hard Drive: adım 7, 2 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement, Hard Drive: adım 7, 2 resimden 2.
    • Unscrew the hard drive.
    • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Carefully push the hard drive away from its port. This should not require substantial force.
    • Lift the hard drive out.
    • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
    • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
  8. Toshiba Satellite L855-S5119 Charger Port Replacement, Back Cover Removal: adım 8, 2 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement, Back Cover Removal: adım 8, 2 resimden 2.
    • Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
    • Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
  9. Toshiba Satellite L855-S5119 Charger Port Replacement, Charger Port: adım 9, 2 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement, Charger Port: adım 9, 2 resimden 2.
    • Locate the DC power port. Note the 4-pin connector attaching the port to the motherboard.
  10. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 10, 2 resimden 1. Toshiba Satellite L855-S5119 Charger Port Replacement: adım 10, 2 resimden 2.
    • Remove the 4 pin female connector from the male connector attached to the motherboard.
    • Lift the DC power port from the bracket holding it in place.
    • There are black plastic housings for the wires, holding the wires in position. Remove the red and black wires connecting the DC Port to the 4-pin power connector from underneath the black plastic housings.
    • Remove the DC Power port and 4 pin connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Shafer
426 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 1,017
