Ana içeriğe geç
Toshiba Satellite P75-A7100 Display Screen Replacement
Mayra Zuniga
Mayra Zuniga ve 2 diğer katkıda bulunanlar
En son July 8, 2022 tarihinde güncellendi
15 - 20 dakika
Orta
This guide will show you how to replace the computer's display screen. Replacing the display screen is necessary when the screen won't turn on or it's cracked. Before conducting our steps, please make sure your computer is powered off.
Neye ihtiyacın var
Aletler
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Toshiba Satellite P75-A7100 Display Screen Replacement, Display Screen: adım 1, 2 resimden 1. Toshiba Satellite P75-A7100 Display Screen Replacement, Display Screen: adım 1, 2 resimden 2.
    • Open the laptop and unscrew each of the screws that are in the corners of the screen using a Phillips #1 screwdriver.
  2. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 2, 3 resimden 1. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 2, 3 resimden 2. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 2, 3 resimden 3.
    • Using a metal spudger, insert the spudger around the edges and the bottom to detach the frame from the screen.
  3. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 3, 1 resimden 1.
    • Remove the frame from the device.
  4. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 4, 3 resimden 1. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 4, 3 resimden 2. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 4, 3 resimden 3.
    • Using a Phillips #1 screwdriver, unscrew all of the screws on the sides of the screen.
  5. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 5, 2 resimden 1. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 5, 2 resimden 2.
    • Disconnect the webcam from the screen and unhook any tape.
  6. Toshiba Satellite P75-A7100 Display Screen Replacement: adım 6, 1 resimden 1.
    • Remove the display from the device and add the new one.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 796
