Ana içeriğe geç
Toshiba Satellite P855-S5312 Disk Drive Replacement
Bishop Clark
Bishop Clark ve 3 diğer katkıda bulunanlar
En son July 31, 2019 tarihinde güncellendi
15 - 20 dakika
Orta
This guide will help the user replace the disk drive on the Toshiba Satellite P855-S5312 . Reasons for replacement include jammed or unresponsive disk. Philips size 0, Tools required for task are phillips size 0 Screwdriver, Plastic Opening Tools, and Pointed edge tool.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: adım 2, 2 resimden 1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: adım 2, 2 resimden 2.
    • Once laptop is turned over with the spine facing you, locate the large L shape panel.
    • Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
  3. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 3, 2 resimden 2.
    • Open the motherboard access cover.
  4. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 4, 2 resimden 2.
    • Using a Philips #0 screwdriver, unscrew the 1.5mm screw located near the left edge of the opening near the mother board.
  5. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 5, 2 resimden 2.
    • Gently pull the entire disk drive assembly out.
  6. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 6, 3 resimden 1. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 6, 3 resimden 2. Toshiba Satellite P855-S5312 Disk Drive Replacement: adım 6, 3 resimden 3.
    • Flip your device over and rotate the side of the optical drive over to you.
    • Unclip the clips on the side of the automatic release.
    • Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
    • Once released slide the aluminum case out.
Sonuç
Bishop Clark
225 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 516
