Ana içeriğe geç
Toshiba Satellite p875 s7200 Screen Replacement
Danny Amado
Danny Amado ve 2 diğer katkıda bulunanlar
En son December 13, 2018 tarihinde güncellendi
1 saat
Orta
İşlem Görüntüleri
If you need to replace the screen, follow this guide. The screen can be accessed by removing the computer from its casing and then removing the hinges. To replace this part, you will need a Phillips 0 screw driver and a plastic opening tool.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite p875 s7200 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift out the battery.
  2. Toshiba Satellite p875 s7200 Screen Replacement: adım 2, 1 resimden 1.
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
  3. Toshiba Satellite p875 s7200 Screen Replacement: adım 3, 2 resimden 1. Toshiba Satellite p875 s7200 Screen Replacement: adım 3, 2 resimden 2.
    • Remove the 6 mm screws around the edges with the Phillips head screw driver. Then remove the 6mm screw holding the disc drive into place.
    • Sliding out the disc drive will reveal the final two 4 mm screws on the bottom of the device.
  4. Toshiba Satellite p875 s7200 Screen Replacement: adım 4, 1 resimden 1.
    • Flip the laptop over to begin the process of removing the keyboard.
    • Use the spudger to pop the keyboard off. Start at the bottom of the keyboard and work your way around.
  5. Toshiba Satellite p875 s7200 Screen Replacement: adım 5, 1 resimden 1.
    • Use the Phillips head screw driver to remove the last 6mm screws holding the case together.
    • The screws are held into elevated columns which are fairly easy to break. Be cautious when removing the screws.
    • After removing the keyboard and the screws, use the spudger around the edges of the laptop to remove the face plate.
  6. Toshiba Satellite p875 s7200 Screen Replacement: adım 6, 2 resimden 1. Toshiba Satellite p875 s7200 Screen Replacement: adım 6, 2 resimden 2.
    • Use the Phillips head screwdriver to remove the 5mm screws on the right speaker.
    • Repeat the process for the left side.
  7. Toshiba Satellite p875 s7200 Screen Replacement: adım 7, 2 resimden 1. Toshiba Satellite p875 s7200 Screen Replacement: adım 7, 2 resimden 2.
    • Flip the laptop over and disconnect the black and white display wires by pulling them upwards.
    • The second image shows the disconnected wires.
    • Flip the laptop back over and pull the black and white wires through their holes in the motherboard.
  8. Toshiba Satellite p875 s7200 Screen Replacement: adım 8, 1 resimden 1.
    • Move the speakers out of the way after removing their holding screws.
    • Remove the two 4mm screws on the hinges on each side of the laptop.
  9. Toshiba Satellite p875 s7200 Screen Replacement: adım 9, 2 resimden 1. Toshiba Satellite p875 s7200 Screen Replacement: adım 9, 2 resimden 2.
    • Use the screw driver to remove the two black disks from the top corners of the display.
    • Remove the 5mm screws that were hidden behind the little black disks.
    • Use the spudger tool to pop the cover off of the edge.
  10. Toshiba Satellite p875 s7200 Screen Replacement: adım 10, 2 resimden 1. Toshiba Satellite p875 s7200 Screen Replacement: adım 10, 2 resimden 2.
    • Remove the two 3 mm screws holding the display in place. Repeat this step for both the left and right sides.
  11. Toshiba Satellite p875 s7200 Screen Replacement: adım 11, 1 resimden 1.
    • Slide the display upwards to remove it.
  12. Toshiba Satellite p875 s7200 Screen Replacement: adım 12, 2 resimden 1. Toshiba Satellite p875 s7200 Screen Replacement: adım 12, 2 resimden 2.
    • Use the screw driver to remove the six 3 mm screws holding the brackets and hinges onto the display.
    • Do not misplace these brackets because they will be used on the new screen.
Sonuç
Danny Amado
823 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G3, Williams Fall 2018 Baylor, Team S1-G3, Williams Fall 2018 üyesi
BU-WILLIAMS-F18S1G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 1,080
