Giriş
When the battery is dead or unable to hold a charge it is time to replace it with a new one. This guide will walk you through the steps to do so. To be safe in removing the other components you need to remove the batter to prevent damage to the laptop.
Neye ihtiyacın var
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Bir başkası bu kılavuzu tamamladı.
