Ana içeriğe geç
Turtle Beach Ear Force Stealth 500P Speaker Replacement
Noah Franklin
Noah Franklin ve 3 diğer katkıda bulunanlar
En son June 30, 2022 tarihinde güncellendi
35 dakika
Orta
If your headphone system isn't providing quality sound through each speaker, it may be necessary to replace the speaker as it could be blown or an internal wiring issue. This replacement should take no longer than 30 minutes with the use of screwdriver and plastic pry tool.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: adım 1, 3 resimden 1. Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: adım 1, 3 resimden 2. Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: adım 1, 3 resimden 3.
    • Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
    • Work circularly until removed.
  2. Turtle Beach Ear Force Stealth 500P Speaker Replacement: adım 2, 2 resimden 1. Turtle Beach Ear Force Stealth 500P Speaker Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
    • Gently pull blue plastic from black housing by hand until separated.
  3. Turtle Beach Ear Force Stealth 500P Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Using metal prying tool, gently slide the tool between the speaker and the blue plastic holder to break up the adhesive.
  4. Turtle Beach Ear Force Stealth 500P Speaker Replacement: adım 4, 1 resimden 1.
    • Depending on how much of the adhesive was able to be removed, you should be able to pry up the speaker assembly using plastic pry tool. If unsuccessful, use metal tool by gently working around speaker using small twisting motions until free.
  5. Turtle Beach Ear Force Stealth 500P Speaker Replacement: adım 5, 2 resimden 1. Turtle Beach Ear Force Stealth 500P Speaker Replacement: adım 5, 2 resimden 2.
    • Using wire cutters, cut the red and black wires connecting the speaker to the circuit board. Be careful to leave at least one inch of wire to use reconnect wires to new speaker.
  6. Turtle Beach Ear Force Stealth 500P Speaker Replacement: adım 6, 1 resimden 1.
    • Use wire strippers to strip a portion of the rubber colored coating on the wires about a quarter inch long from both the wires connected to the circuit board and the two red and blacks wires connected to the new speaker.
  7. Turtle Beach Ear Force Stealth 500P Speaker Replacement: adım 7, 1 resimden 1.
    • Twist together the matching pairs of un-shielded copper wire (black on black and red on red) and cover with wire connectors to prevent shorting.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Noah Franklin
451 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Shastany Fall 2015 UMass Dartmouth, Team 2-3, Shastany Fall 2015 üyesi
UMASSD-SHASTANY-F15S2G3
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
This is the first guide I've found that covers how the speaker is mounted to the plate. Thanks!
Michael Merrell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 37
Her zaman: 3,768
