Ana içeriğe geç
Turtle Beach PX22 Microphone Replacement
James de Iturrondo
James de Iturrondo ve 2 diğer katkıda bulunanlar
En son June 30, 2022 tarihinde güncellendi
25 - 30 dakika
Zor
If your microphone does not work after troubleshooting with our guides it may need to be replaced. This guide will show the user how to remove a broken microphone and replace it with a new microphone.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Turtle Beach PX22 Microphone Replacement, Microphone: adım 1, 3 resimden 1. Turtle Beach PX22 Microphone Replacement, Microphone: adım 1, 3 resimden 2. Turtle Beach PX22 Microphone Replacement, Microphone: adım 1, 3 resimden 3.
    • Use your fingers to peel off ear cushion by pinching and pulling off the leather.
    • Use the Philips #00 head screwdriver to remove three screws around the speaker (9/32 in length, 1/8 inch head)
    • The housing will comes loose. Take note of position of the wires.
  2. Turtle Beach PX22 Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the 9/32 inch screw with a Philips 2 screwdriver to gain access to microphone.
    • You may need to pull the wire with the knot out of the way of the screw.
  3. Turtle Beach PX22 Microphone Replacement: adım 3, 1 resimden 1.
    • Apply heat to the circled wires on the circuit board with a heat gun.
    • Insert the new microphone and solder the wires into the correct positions.
    • Pull the excess microphone wire back into the speaker housing.
    • Use the Philips #2 screwdriver to replace the screw and fix the microphone.
    • Hold the microphone neck so that it does no rotate when screwing.
  4. Turtle Beach PX22 Microphone Replacement: adım 4, 3 resimden 1. Turtle Beach PX22 Microphone Replacement: adım 4, 3 resimden 2. Turtle Beach PX22 Microphone Replacement: adım 4, 3 resimden 3.
    • Position the speaker on the headset so that the screw holes line up. It should click into place.
    • Screw in the 3 screws with the 00 Philips head screwdriver.
    • Place the new cushion against speaker and wrap the leather around the plastic. Do this by working around the cushion to get all of the leather around the plastic.
    • Use the plastic opening tool to tuck excess leather inside the headset.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
James de Iturrondo
709 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Duarte Spring 2015 UMass Dartmouth, Team 3-1, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G1
4 Üyeler
8 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where do we buy the mic?
Brit B - Yanıt
could someone help me say what each and every on of those wire points on this logic board goes to? like 1,2,3,4,5 and 6, what do they go to???
alexalv55 - Yanıt
i need the cable for my px 24 it broke in my phone how do i get a new cable to fix my px 24 headset
rjbubba1960 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 6,874
