Ana içeriğe geç
VTech InnoTab Max Battery Replacement
Jacob Schioppo
Jacob Schioppo ve 4 diğer katkıda bulunanlar
En son March 4, 2024 tarihinde güncellendi
10 - 20 dakika
Orta
This guide will show how to replace the battery in the VTech InnoTab Max.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. VTech InnoTab Max Battery Replacement, Cover: adım 1, 3 resimden 1. VTech InnoTab Max Battery Replacement, Cover: adım 1, 3 resimden 2. VTech InnoTab Max Battery Replacement, Cover: adım 1, 3 resimden 3.
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Battery Replacement: adım 2, 3 resimden 1. VTech InnoTab Max Battery Replacement: adım 2, 3 resimden 2. VTech InnoTab Max Battery Replacement: adım 2, 3 resimden 3.
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
    Don’t forget the 2 screws under the cartridge.
    Kim Sihota - Yanıt
  3. VTech InnoTab Max Battery Replacement: adım 3, 2 resimden 1. VTech InnoTab Max Battery Replacement: adım 3, 2 resimden 2.
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Battery Replacement: adım 4, 2 resimden 1. VTech InnoTab Max Battery Replacement: adım 4, 2 resimden 2.
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
  6. VTech InnoTab Max Battery Replacement: adım 6, 3 resimden 1. VTech InnoTab Max Battery Replacement: adım 6, 3 resimden 2. VTech InnoTab Max Battery Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
    The double sided tape used to hold down the battery is overkill. I actually had to slice through it CAREFULLY in order to release the battery.
    Kim Sihota - Yanıt
  7. VTech InnoTab Max Battery Replacement: adım 7, 3 resimden 1. VTech InnoTab Max Battery Replacement: adım 7, 3 resimden 2. VTech InnoTab Max Battery Replacement: adım 7, 3 resimden 3.
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
  8. VTech InnoTab Max Battery Replacement: adım 8, 1 resimden 1.
    • The battery is now fully disconnected.
    What type of battery???
    Harold W - Yanıt
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Jacob Schioppo
564 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Lacy Spring 2017 USF Tampa, Team S5-G5, Lacy Spring 2017 üyesi
USFT-LACY-S17S5G5
3 Üyeler
10 adet Kılavuz yazıldı
10Kılavuz Yorumları
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - Yanıt
Where can we purchase a replacement battery
Frank Godon - Yanıt
Where can we buy a replacement battery
Frank Godon - Yanıt
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - Yanıt
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - Yanıt
I used a replacement battery for a tablet w/a red, black and white bare wire. I cut the wire long with connector attached off the old battery. I spliced them and it now works and charges. Also had to do some trimming and shaving of the compartment with an exacto knife so battery would fit. I am sure if you look on eBay you can find a bare wire black, red and white. I got mine on ebay for rca tab. but it was wrong, RCA only uses Black and red wire.
Kathleen A Dombrowski - Yanıt
Does someone know where to buy this battery, or Which battery (exact specs) can be used as a replacement?
Thanks
peltiarn - Yanıt
Bonjour
où puis je trouver cette batterie ?
Merci
alainparent62 - Yanıt
Where can I get replacement batteries for innoTab3S
gwendolynheatley59 - Yanıt
the charger port is broken
ipod56 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 63
Her zaman: 14,757
