Ana içeriğe geç
Valve Index Headset Head Strap Replacement
Sam Omiotek
Sam Omiotek ve 4 diğer katkıda bulunanlar
En son October 20, 2023 tarihinde güncellendi
30 dakika - 1 saat
Orta
Follow this guide to replace the head strap on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Valve Index Headset Head Strap Replacement, Adjust the eye tube relief: adım 1, 1 resimden 1.
    • Twist the eye tube relief knob clockwise to fully extend it.
  2. Valve Index Headset Head Strap Replacement, Remove the eye relief knob: adım 2, 3 resimden 1. Valve Index Headset Head Strap Replacement, Remove the eye relief knob: adım 2, 3 resimden 2. Valve Index Headset Head Strap Replacement, Remove the eye relief knob: adım 2, 3 resimden 3.
    • Insert an opening pick between the eye relief knob and the head strap.
    • Gently pry with the opening pick while pulling the eye relief knob off until it is removed.
  3. Valve Index Headset Head Strap Replacement, Reassembly tip: adım 3, 1 resimden 1.
    • During reassembly, ensure the eye relief knob is aligned with the shaft before pressing it on.
  4. Valve Index Headset Head Strap Replacement, Remove the head strap clip: adım 4, 3 resimden 1. Valve Index Headset Head Strap Replacement, Remove the head strap clip: adım 4, 3 resimden 2. Valve Index Headset Head Strap Replacement, Remove the head strap clip: adım 4, 3 resimden 3.
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
    Do you sell replacement clips?
    TomCatT - Yanıt
    I didn't really see the need to unclip this or do the next step so I skipped it. It seems easy enough to unplug the cable while it's still attached to these, so unless you're really concerned about the cable bending a little more than it already does it seems unnecessary.
    Stephen Smith - Yanıt
  5. Valve Index Headset Head Strap Replacement, Remove the face gasket: adım 5, 2 resimden 1. Valve Index Headset Head Strap Replacement, Remove the face gasket: adım 5, 2 resimden 2.
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  6. Valve Index Headset Head Strap Replacement, Separate the cable from the head strap guide: adım 6, 2 resimden 1. Valve Index Headset Head Strap Replacement, Separate the cable from the head strap guide: adım 6, 2 resimden 2.
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  7. Valve Index Headset Head Strap Replacement, Disconnect the tether cable: adım 7, 2 resimden 1. Valve Index Headset Head Strap Replacement, Disconnect the tether cable: adım 7, 2 resimden 2.
    • Pull the tether cable straight back out of the headset.
  8. Valve Index Headset Head Strap Replacement, Head strap removal information: adım 8, 2 resimden 1. Valve Index Headset Head Strap Replacement, Head strap removal information: adım 8, 2 resimden 2.
    • The head strap can be removed without removing the face gasket bezel if you have the correct length driver. If you are using your iFixit T6 driver, skip this step and proceed with removing the face gasket bezel.
    • Your T6 driver must have a shaft longer than 18 mm (0.7 in) and an overall length less than 140 mm (5.5 in).
    • Insert your T6 Torx screwdriver into the hole on the face gasket bezel to remove the captive screw securing the left side of the head strap.
    • Skip to step 12.
    Use a T6 driver on the screw securing the left side of the headband to the device. Usage of a T5 bit will damage this screw and make it impossible to remove.
    Arc7ic Kenai - Yanıt
    Where may I find a replacement screw for the left side?
    TomCatT - Yanıt
    I need a replacement screw for the left side as well. :(
    beaudamion - Yanıt
    ifixit kit did not come with t6 torx screwdriver so had to buy it separately.
    FIXITWILLY - Yanıt
    What kind of screw is located where the red circle shows? I know its supposed to be a captive screw but it is missing on my right side. I just need to know the specs so i can order a replacement.
    Josh Gordash - Yanıt
  9. Valve Index Headset Head Strap Replacement, Remove the face gasket bezel: adım 9, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
  10. Valve Index Headset Head Strap Replacement: adım 10, 2 resimden 1. Valve Index Headset Head Strap Replacement: adım 10, 2 resimden 2.
    • Do not try and pry the face gasket bezel off, or you will damage the headset.
    • Grab the left edge of the face gasket bezel with your hand and slide it off of the headset.
    • During reassembly, visually verify the clips on the face gasket bezel are aligned with the headset before sliding it into place.
    This was a little tricky. There's a latching mechanism inside the bezel that requires squeezing the sides a bit to unlatch. In exactly the same hand position as the photo, you need to squeeze. Absolutely don't pry it off or it will snap.
    Scyntrian - Yanıt
  11. Valve Index Headset Head Strap Replacement: adım 11, 3 resimden 1. Valve Index Headset Head Strap Replacement: adım 11, 3 resimden 2. Valve Index Headset Head Strap Replacement: adım 11, 3 resimden 3.
    • Repeat the previous step for the right side of the face gasket bezel.
    • Remove the face gasket bezel.
  12. Valve Index Headset Head Strap Replacement, Remove the head strap: adım 12, 1 resimden 1.
    • Use a T6 Torx screwdriver to remove the two 6.6 mm screws underneath the eye relief knob.
    these are T6 screws, not T5. a T5 will drive them, but it's not ideal.
    Choccy - Yanıt
    Theeeeese are the two screws that i found "after 3 years today" that comes loose over time of taking the headset on and off. And it is this that causes the sound glitching problem in the earphones. tried to thighten the earphones and cleaned them 100s of times. And today i saw this. So if you have problems with sound. thigten the screws on strap (left one is harder) But result is night and day.
    jonthe1982 - Yanıt
  13. Valve Index Headset Head Strap Replacement: adım 13, 2 resimden 1. Valve Index Headset Head Strap Replacement: adım 13, 2 resimden 2.
    • Pull the right end of the head strap straight off of the headset.
    • During reassembly, ensure the head strap is correctly positioned on the alignment post.
  14. Valve Index Headset Head Strap Replacement: adım 14, 2 resimden 1. Valve Index Headset Head Strap Replacement: adım 14, 2 resimden 2.
    • Use a T6 Torx screwdriver to loosen the screw securing the left side of the head strap to the headset.
    • Don't let this screw fall inside the headset. It is not a captive screw and is difficult to retrieve.
    • If the black plastic cap surrounding the cap limits access, use an opening pick to remove the cap.
    It looks like a step is missing for removing the inner lining of the headset
    Nirvash - Yanıt
    Thanks for noticing this! I am correcting it now.
    Sam Omiotek -
    this is also a T6 screw, not T5.
    Choccy - Yanıt
    This is a T6 screw and there is a plastic cap/ring that needs to be removed in order to loose the screw.
    https://imgur.com/kJN2rj7
    JimMcBubbles - Yanıt
    Yes had to find a T6 bit that was not included in the kit
    chad harding - Yanıt
    in trying to attach the new strap this screw won't tighten all the way back in, it also won't back back out
    kentaro wingren - Yanıt
    use the t6 with the hole in it
    Tanther Panther -
    the proper bit was included in the kit, but its the t6 torx with the hole in it idk what that's called, but my screw was slightly stripped and wasn't screwing back in all the way and I was wondering why it wasn't tightening, luckily even after applying pressure and twisting the wrong bit in there for about 30 turns the bit with the hole worked for securing the screw. there is also a small plastic cap/ring that you can spudge off to make it easier
    Tanther Panther - Yanıt
    If the screw is lost how do I replace it? I lost the screw.
    jbonomi - Yanıt
    I edited the guide to add the missing step for removing the plastic cap here. The screw cannot be removed until you pry it off.
    Firon - Yanıt
    if having a too short/ to thick t6 driver is an issue the small collar that limits ability to get to the t6 screw is only held by friction fit so can be removed with tweezers to allow a fatter t6 driver in to remove the screw as hole is wider ~
    Elair - Yanıt
    Does the T6 Screwdriver need to be a certain length to get to the screw inside that hole? I think mine is too short and is bumping the outside of the plastic circle, not reaching the screw inside. Idk what else I could be doing wrong here
    Joseph Stardust - Yanıt
    Does anyone know the size of the screw I lost mine
    Alexander Sluss - Yanıt
  15. Valve Index Headset Head Strap Replacement: adım 15, 2 resimden 1. Valve Index Headset Head Strap Replacement: adım 15, 2 resimden 2.
    • Pull the left end of the head strap straight off the headset.
    • During reassembly, be careful not to let the screw fall into the headset. Use your driver to hold it in place from behind if necessary.
  16. Valve Index Headset Head Strap Replacement: adım 16, 2 resimden 1. Valve Index Headset Head Strap Replacement: adım 16, 2 resimden 2.
    • Slide the head strap band out from the headset.
    • The head strap is now fully removed.
    reassembly tip, put your spudger in the front part and gently wiggle the STRAP it as you push it in, this will gently angle it up and around. https://prnt.sc/XnReN20WAKcV
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
26 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
84.916 İtibar
290 adet Kılavuz yazıldı
8Kılavuz Yorumları
I'm having troubles with my left speaker, I just got done replacing it, is this the next step I wanna try in troubleshooting it? The last thing I want to do is buy a whole new headset? It cuts out when the strap moves. I've already replaced the cable as well.
Who? - Yanıt
Try to tighten left part of the strap (step 14)
Анатолий Прилуцкий -
When will they be in stock again
lightning gaming - Yanıt
Any word on restocking for this part?
Charles Allen - Yanıt
No stock for 2 Years now. Great...
Ricky Bobby - Yanıt
You can get a refurbished one on tundra labs
Alicia Johnson -
If you go to tundra labs website. They have refurbished head straps and stock. I just got one and it's basically like new. Hope this helps..
tunergy takedown - Yanıt
The piece that the top head strap band threads through is also broken on mine. What part besides the this one do I need?
Heather Savant - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 186
Son 30 gün: 935
Her zaman: 41,398
