Ana içeriğe geç
Valve Index Headset Motherboard Replacement
Neye ihtiyacın var
  1. Valve Index Headset Motherboard Replacement, Remove the front cover: adım 1, 2 resimden 1. Valve Index Headset Motherboard Replacement, Remove the front cover: adım 1, 2 resimden 2.
    • Use your hand to pull the front cover straight off of the front of the headset.
    • The front cover is held in place by four magnets that secure to screws in the motherboard cover.
    • Before installing a front cover, ensure the four screws securing the motherboard cover are installed. Otherwise, the front cover will not stay in place.
    Whoever wrote this is a moron.
    Sam Omiotek - Yanıt
    My god. Thank you. This was an extremely helpful guide. I just couldn't get it off!
    Theu - Yanıt
  2. Valve Index Headset Motherboard Replacement, Remove the motherboard cover: adım 2, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the four 5.4 mm screws securing the motherboard cover to the headset.
  3. Valve Index Headset Motherboard Replacement: adım 3, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the motherboard cover from the headset.
  4. Valve Index Headset Motherboard Replacement, Remove the front fascia: adım 4, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the following eight screws from the front fascia:
    • Four 6.3 mm screws with fine threads
    • Four 6.0 mm screws with coarse threads
    This is your last chance at catching the ipd adjustment groove on the right eye tube and catch the little knob on the back of the motherboard with it. (Just forgot about it myself and thankfully you can do it from this step the latest
    Blecha100 - Yanıt
  5. Valve Index Headset Motherboard Replacement: adım 5, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 5, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 5, 3 resimden 3.
    • Use a spudger to unlock the ZIF connector at the top-left corner of the motherboard.
    • Disconnect the FPC ribbon cable from the motherboard.
  6. Valve Index Headset Motherboard Replacement: adım 6, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 6, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 6, 3 resimden 3.
    • Use a spudger to unlock the ZIF connector at the top-right corner of the motherboard.
    • Disconnect the FPC ribbon cable.
  7. Valve Index Headset Motherboard Replacement: adım 7, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the press connector from the bottom-left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. Valve Index Headset Motherboard Replacement: adım 8, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the press connector from the bottom-right corner of the motherboard.
  9. Valve Index Headset Motherboard Replacement: adım 9, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 9, 2 resimden 2.
    • Insert an opening pick in between the front fascia and the headset.
    • Slide the opening pick over to separate the front fascia from the headset.
    there are adhesive strips at the 11:30, 01:30, 05:30, and 06:30 positions. Slow, gentle prying removes the front fascia. There are no clips holding it in place.
    JimMcBubbles - Yanıt
  10. Valve Index Headset Motherboard Replacement: adım 10, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 10, 2 resimden 2.
    • Continue sliding the opening pick along the perimeter of the front fascia until all edges are free.
    Frontblende ist sowohl oben als auch unten an zwei Stellen leicht eingeklebt.
    Falls die Frontblende bei Schritt 21 nicht abgeht, könnte der Klebstoff dafür verantwortlich sein.
    In dem Fall kann man ihn mit dem Plektrum von der Blende lösen.
    Grober Feinmotoriker - Yanıt
  11. Valve Index Headset Motherboard Replacement: adım 11, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the front fascia.
  12. Valve Index Headset Motherboard Replacement, Remove the motherboard: adım 12, 1 resimden 1.
    • Note the seven cables that must be disconnected in the following steps before the motherboard can be removed.
    note that the wheel that adjusts the distance between the eyes goes over the boar. So you will tuck the board under it.
    Michael Hehe - Yanıt
  13. Valve Index Headset Motherboard Replacement: adım 13, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 13, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 13, 3 resimden 3.
    • Use the flat end of a spudger to unlock the wide ZIF connector on the left side of the motherboard.
  14. Valve Index Headset Motherboard Replacement: adım 14, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 14, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the press connector near the bottom-left edge of the motherboard.
    • During reassembly, be sure this cable is not trapped underneath the motherboard.
  15. Valve Index Headset Motherboard Replacement: adım 15, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 15, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 15, 3 resimden 3.
    • Use your finger or an opening tool to unlock the display cable connector at the top of the motherboard.
    • Carefully disconnect the display cable connector.
    this one is pretty difficult, and could use some more explanation (esp since the teardown video of the index skips it completely). you need to lift up on the corner of the cover, and then use the pointy end of the spudger to slowly wiggle the cable UP and out of the connector, a little at a time on each side.
    Owen Smith - Yanıt
    Good tip, this is not a press connector. Once the cover is swung open it slides out upwards not away from the board
    Stephen Smith - Yanıt
  16. Valve Index Headset Motherboard Replacement: adım 16, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 16, 2 resimden 2.
    • Use the pointed end of a spudger to gently disconnect the bundled cable connector from the top-right corner of the motherboard.
    don't push up on the indented plastic
    Jose Zamora - Yanıt
    This pops out towards you, do not try to push up.
    Storm DPD - Yanıt
    thank you to the comments about not pushing up!
    Aeon Faye - Yanıt
    Simlarily: when reassembling, line the cable up above the insert, and push slightly toward the MB. You'll hear a tiny click when it slots in.
    Joj - Yanıt
  17. Valve Index Headset Motherboard Replacement: adım 17, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 17, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 17, 3 resimden 3.
    • Use the pointed end of a spudger to unlock the ZIF connector next to the USB port on the motherboard.
    • Disconnect the FPC cable from the motherboard.
    • During reassembly, make sure this ribbon cable is not trapped under the motherboard.
    Not sure if this is on every headset, but mine had adhesive holding this cable to the motherboard and to the press connector cable. Be very careful peeling these apart, the adhesive is a little strong. Using the guitar-pick looking thing from the fix kit managed to separate them for me, but it might have been sheer luck lol.
    Owen Smith - Yanıt
  18. Valve Index Headset Motherboard Replacement: adım 18, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 18, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the press connector below the USB port on the motherboard.
    • During reassembly, make sure this cable is not trapped under the motherboard.
  19. Valve Index Headset Motherboard Replacement: adım 19, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 19, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 19, 3 resimden 3.
    • Use a spudger to unlock the wide ZIF connector near the right edge of the motherboard.
  20. Valve Index Headset Motherboard Replacement: adım 20, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the five 6.0 mm screws securing the motherboard to the headset.
    These are a set of 5 coarse threaded screws.
    Patrick Hartge - Yanıt
  21. Valve Index Headset Motherboard Replacement: adım 21, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 21, 2 resimden 2.
    • Grab the motherboard by the USB port and carefully remove it from the headset.
    • During reassembly, be very careful not to trap any of the previously disconnected cables under the motherboard.
    During reassembly be sure to align the ipd slider with the gap on the back of the right eye tube. The ipd adjustment slider is located on the top left of the motherboard and is very easy to miss.
    Failing to align that the motherboard and the eyetube will result in resistance while adjusting the ipd, as well as an incorrect ipd being used in steamVR (which doesn't feel too great).
    Aux - Yanıt
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Sam Omiotek
85.261 İtibar
290 adet Kılavuz yazıldı
5Kılavuz Yorumları
Where can I buy the motherboard? It doesn't look like ifixit has them.
Curtis Gray - Yanıt
I have this same question.
Patrick Hartge -
you would think the replacement motherboard would be in the list of required items. Where are you supposed to buy this from?
Grant Za - Yanıt
Same question ,where do i get a replacement main board
Gifted Misfit - Yanıt
Daniel O'Sullivan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 48
Son 30 gün: 260
Her zaman: 11,031
