Ana içeriğe geç
Visual Land Prestige 7G Battery Replacement
Neye ihtiyacın var
  1. Visual Land Prestige 7G Battery Replacement, Backplate: adım 1, 2 resimden 1. Visual Land Prestige 7G Battery Replacement, Backplate: adım 1, 2 resimden 2.
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Battery Replacement: adım 2, 1 resimden 1.
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Battery Replacement: adım 3, 2 resimden 1. Visual Land Prestige 7G Battery Replacement: adım 3, 2 resimden 2.
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Battery Replacement, Battery: adım 4, 3 resimden 1. Visual Land Prestige 7G Battery Replacement, Battery: adım 4, 3 resimden 2. Visual Land Prestige 7G Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Use an opening tool to lift the battery from the device.
    • Be careful to not use a metal spudger or tool, as it can bend and harm the battery.
  5. Visual Land Prestige 7G Battery Replacement: adım 5, 2 resimden 1. Visual Land Prestige 7G Battery Replacement: adım 5, 2 resimden 2.
    • Take your soldering gun and carefully remove the red and black wire connecting the battery to the motherboard.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Brandon Gray
207 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 76
