Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If the power button on your Vivitar Vivicam T027 digital camera breaks or gets jammed, you may need to replace it. This guide will show you how.
Note: This repair requires soldering. View the soldering guide for more information.
Neye ihtiyacın var
Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
You will find one screw on the top, one on the bottom, and one on each side of the camera.
