Ana içeriğe geç
Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement
Manuel Haeussermann
Manuel Haeussermann ve başka bir katkıda bulunan
En son March 23, 2024 tarihinde güncellendi
30 - 50 dakika
Orta
Use this guide to replace a damaged or worn-down bumper cover on your Xbox Series X|S Controller (model 1914).
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: adım 1, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: adım 1, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: adım 1, 3 resimden 3.
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: adım 2, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: adım 2, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: adım 2, 3 resimden 3.
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 3, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 3, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 3, 3 resimden 3.
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: adım 4, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: adım 4, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: adım 4, 3 resimden 3.
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: adım 5, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: adım 5, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: adım 5, 3 resimden 3.
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 6, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 6, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: adım 6, 3 resimden 3.
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: adım 7, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: adım 7, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: adım 7, 3 resimden 3.
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: adım 8, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: adım 8, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: adım 8, 3 resimden 3.
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Reposition the battery compartment sticker: adım 9, 2 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Reposition the battery compartment sticker: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unfasten the top housing: adım 10, 2 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unfasten the top housing: adım 10, 2 resimden 2.
    • Use a Torx T8 Security driver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: adım 11, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: adım 11, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: adım 11, 3 resimden 3.
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: adım 12, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: adım 12, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: adım 12, 3 resimden 3.
    • The USB-C port cover is held in place by two plastic clips.
    • Insert the flat end of a spudger under the right USB-C port cover clip.
    • Pry up with the spudger to release the clip.
    • Repeat the procedure to release the left clip.
  13. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the USB-C port cover: adım 13, 2 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the USB-C port cover: adım 13, 2 resimden 2.
    • Remove the USB-C port cover.
  14. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: adım 14, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: adım 14, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: adım 14, 3 resimden 3.
    • Insert the point of a spudger between the clip on the outer edge of the right bumper and the midframe.
    • Pry out with the spudger to release the right side of the bumper cover.
  15. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: adım 15, 3 resimden 1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: adım 15, 3 resimden 2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: adım 15, 3 resimden 3.
    • Insert the point of a spudger between the clip on the outer edge of the left bumper and the midframe.
    • Pry out with the spudger to release the left side of the bumper cover.
  16. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the bumper cover: adım 16, 1 resimden 1.
    • Remove the bumper cover.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Manuel Haeussermann
19.506 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.521 adet Kılavuz yazıldı
4 Yorum
The left bumper button broke for me. The plastic post that presses the button just snapped. This helped me replace the bumper. Good guide.
Jordan Cooper - Yanıt
Removing the handle covers was the hardest part, largely because I was afraid I would break them if I asserted too much pressure. Once I got those off, it was pretty easy. The opening tool and spudger recommended in the tools section were useful--they did their jobs very well--but I suspect this could have been accomplished with any kind of replacement tool(s) you might have on hand; however, since I bought them I'm sure they'll come in handy in future projects. I would argue the TR8 Torx Security Screwdriver is really the only piece of equipment that is specifically required.
Russ Looney - Yanıt
£50 for a new controller, cost but £26 for the tools and spare part, took maybe 10 minutes, and you cannot tell one bit that my controller has been tampered with or fixed
feel truly accomplished, saved money - and now i have the tools for the next challenge, be it my own, or a friends'
Haydn Buchanan - Yanıt
I just broke the bumper cover while following steps 14 and 15 - the guide failed to mention the little plastic posts that actually press the RB/LB buttons are easily snapped while using the spudger to pry the bumper clips. The posts are visible in the picture for step 16 - the long protruding parts nearest the centre of the cover. Maybe consider adding a warning. I'm going to try to glue the posts back on but otherwise will have to just buy a replacement bumper cover part. Excellent guide otherwise.
owwynn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 300
Son 30 gün: 976
Her zaman: 15,366
